33 chevy
4
5
45
Topic: 33 chevy (Read 130828 times)
Re: 33 chevy
Reply #30 on:
April 09, 2015, 07:42:40 PM »
Yes nice job looking good.
Re: 33 chevy
Reply #31 on:
April 09, 2015, 11:12:31 PM »
Top notch work!
Re: 33 chevy
Reply #32 on:
April 10, 2015, 12:27:32 PM »
Great woodwork!!
Re: 33 chevy
Reply #33 on:
April 30, 2015, 07:20:20 PM »
Got the sand blaster out and blasted rear fender wells and used small sand blast gun for the corners of the doors...almost done have direct to metal primer bought, just another go around and a DA job, and ready to primer
Last Edit: April 30, 2015, 07:26:46 PM by FATnLOW
Re: 33 chevy
Reply #34 on:
April 30, 2015, 07:32:33 PM »
Here yow go Fatnlow had these pictures from the street Rod Nationals 2014 in Knoxville Tn.They might help you to get really motivated
Re: 33 chevy
Reply #35 on:
April 30, 2015, 07:36:44 PM »
You won't believe it..but I have all the paint and supplies for Plum Crazy paint job Thanks for the Photos....I see it coming together..
Re: 33 chevy
Reply #36 on:
May 02, 2015, 03:47:25 PM »
Shot some primer.. High Teck Direct To Metal primer..... needed to cover all that expose bare metal , checked body for any missed spots and DA the entire body, been a busy day
Re: 33 chevy
Reply #37 on:
May 08, 2015, 05:11:16 PM »
Doing work on rear roll pan and hopefully setting up steering using ram horn exhaust manifolds ...
Re: 33 chevy
Reply #38 on:
May 13, 2015, 05:20:23 PM »
Set dummy motor and transmission with all the correct mounts back in
Re: 33 chevy
Reply #39 on:
May 14, 2015, 04:36:04 PM »
Fatnlow it's looking good, looks like your primer laid down smooth
Re: 33 chevy
Reply #40 on:
June 17, 2015, 05:39:16 PM »
Filling a roof/ top opening...after searching for a station wagon or van top to use as a donor with out any luck, I ended up with one from a salvage yard that had a flood sale. Paid $32 for the top..i cut it off at the pillars so I would have the bracing if I need them, Photos are in the rough cut fitting stage
Re: 33 chevy
Reply #41 on:
June 17, 2015, 08:07:34 PM »
Looks like it'll fit pretty good. What vehicle did it come off of?
Re: 33 chevy
Reply #42 on:
June 17, 2015, 08:30:55 PM »
Tom.... So far I'm happy with the fit, it laid down well... and I thought 6 ribs might look odd but I believe I will like the look of the top.. I removed it from a 2001 Jeep Grand Cherokee, I Still Need to cut it to length
Last Edit: August 25, 2015, 08:07:53 PM by FATnLOW
Re: 33 chevy
Reply #43 on:
July 08, 2015, 04:58:43 PM »
Top is welded in.... 1st round of filler in....Then a lot of blocking ..
Re: 33 chevy
Reply #44 on:
July 08, 2015, 05:36:25 PM »
Top looks real good FATnLOW. I like the look of those flat top ribs vs the round top ones.
4
5
45
33 chevy
