Author Topic: 33 chevy  (Read 587368 times)
Re: 33 chevy
« Reply #30 on: April 09, 2015, 07:42:40 PM »
Yes nice job looking good.
Re: 33 chevy
« Reply #31 on: April 09, 2015, 11:12:31 PM »
Top notch work!
Re: 33 chevy
« Reply #32 on: April 10, 2015, 12:27:32 PM »
Great woodwork!!
Re: 33 chevy
« Reply #33 on: April 30, 2015, 07:20:20 PM »
Got the sand blaster out and blasted rear fender wells and used  small  sand blast gun for the corners of the doors...almost done  have  direct to metal primer bought,  just another go around  and a   DA  job, and ready to primer
« Last Edit: April 30, 2015, 07:26:46 PM by FATnLOW »
Re: 33 chevy
« Reply #34 on: April 30, 2015, 07:32:33 PM »
Here yow go Fatnlow had these pictures from the street Rod Nationals 2014 in Knoxville Tn.They might help you to get really motivated ;)
Re: 33 chevy
« Reply #35 on: April 30, 2015, 07:36:44 PM »
You  won't believe it..but  I have  all the paint  and supplies  for Plum Crazy  paint job   Thanks  for the Photos....I  see it coming together..
Re: 33 chevy
« Reply #36 on: May 02, 2015, 03:47:25 PM »
Shot some primer..   High Teck  Direct To Metal primer..... needed to cover all that expose bare metal  , checked body for any missed spots and DA the entire body, been a busy day
Re: 33 chevy
« Reply #37 on: May 08, 2015, 05:11:16 PM »
Doing work on rear roll pan and hopefully setting up steering using ram horn exhaust manifolds ...
Re: 33 chevy
« Reply #38 on: May 13, 2015, 05:20:23 PM »
Set dummy motor and transmission with all the correct mounts back in
Re: 33 chevy
« Reply #39 on: May 14, 2015, 04:36:04 PM »
Fatnlow it's looking good, looks like your primer laid down smooth
Re: 33 chevy
« Reply #40 on: June 17, 2015, 05:39:16 PM »
Filling a roof/ top opening...after searching for a station wagon or van top to use as a donor  with out any luck, I ended up with one from a salvage yard that had a flood sale. Paid   $32  for the top..i cut it off at the pillars so I would have the bracing if I need them, Photos are in the rough cut fitting stage
Re: 33 chevy
« Reply #41 on: June 17, 2015, 08:07:34 PM »
Looks like it'll fit pretty good.  What vehicle did it come off of?
Re: 33 chevy
« Reply #42 on: June 17, 2015, 08:30:55 PM »
Tom....  So far I'm happy with the fit,  it  laid down well... and  I thought 6 ribs might look odd but I believe I will like the look of the top..  I removed it from a 2001 Jeep Grand Cherokee, I  Still Need to cut it to length
« Last Edit: August 25, 2015, 08:07:53 PM by FATnLOW »
Re: 33 chevy
« Reply #43 on: July 08, 2015, 04:58:43 PM »
Top is welded in.... 1st round of filler in....Then a lot of blocking ..
Re: 33 chevy
« Reply #44 on: July 08, 2015, 05:36:25 PM »
Top looks real good FATnLOW.  I like the look of those flat top ribs vs the round top ones.
