Miscellaneous
33 chevy
3
4
5
6
48
Topic: 33 chevy (Read 586765 times)
Re: 33 chevy
Reply #45 on:
July 08, 2015, 06:01:29 PM »
Fatnlow that roof looks great looks like it was made for it. Nice choice.
Re: 33 chevy
Reply #46 on:
July 08, 2015, 07:42:03 PM »
Nice
Re: 33 chevy
Reply #47 on:
July 09, 2015, 10:27:06 AM »
Looks great, FATnLOW. I like those flat ribs too.
Re: 33 chevy
Reply #48 on:
July 09, 2015, 04:20:13 PM »
there must be a way to re-inforce the insert metal roof panel , so that it cannot flex with the wind. Usually after a period of 5 years or so all that bondo starts to crack from the welded insert.
I am thinking that using tubing or hardwood cross bracing right up against the roof panel might help alleviate a potential problem.
Has anybody else noticed this problem on cars at shows?
Oh ya, the roof insert really looks good with flat tops
Re: 33 chevy
Reply #49 on:
July 09, 2015, 04:44:13 PM »
When placing something against the roof to help support it from the wind it also needs to be able to flex with the expansion from the heat also.
Re: 33 chevy
Reply #50 on:
July 09, 2015, 05:04:29 PM »
My plan is to run the metal bracing along the roof and leave about a 1/4" gap to be filled in with automotive spray foam. Actually already framed my car....just need to foam it after I finish the roof....the spray foam needs to be firm but flexible.
Re: 33 chevy
Reply #51 on:
July 09, 2015, 05:05:47 PM »
I used four lengths of "L" channel. I ground them to the curvature of the inside of the roof, fit them within a 1/16" to the roof and welded them to square tubing I ran around the perimeter and above the door openings. It helped stiffen up the entire upper section of the body and roof and the flat part of the "L" gave me something to secure the headliner to. I'm sorry but I have no pictures.
Re: 33 chevy
Reply #52 on:
July 09, 2015, 07:29:04 PM »
good replies, that's what I was hoping to see for members of this rusty bowtie community to help them build better cars/street rods thru innovation in techniques......
anybody else have anything to add..........?
happiness is a job well done and lasts and lasts
Re: 33 chevy
Reply #53 on:
July 09, 2015, 08:50:56 PM »
Bracing for the roof....In the front and back I cut a piece of flat stock the same arc of the roof hole and tack welded that roof to it. Then I used 1x3 tubing for the other 2 braces welded that to 1x1 sq tubing on the side that runs from front to back . On top of the front 1x3 I used 3/4" pipe foam wrap, opening it along the slit and used spray glue to hold that in place (the donor roof had foam glued on the rib brace to the roof that went from side to side) so I thought about using the pipe wrap insulation Also used Liquid Nails adhesive on top of the foam to the roof.
On the next brace I welded a 3/8 inch round stock to the 1 x 3 stock , and I'm going to glue more foam on the back side,
Photo shows plastic wire ties holding pipe wrap in place after I sprayed glue on ,,in between wire ties Liquid nails was used
then I set the top on over the liquid nails
Last Edit: July 09, 2015, 08:55:23 PM by FATnLOW
Re: 33 chevy
Reply #54 on:
July 11, 2015, 10:31:49 AM »
I really like that top on there. Nice work
Re: 33 chevy
Reply #55 on:
July 12, 2015, 07:12:36 PM »
Here's how I did my flat roof bracing, I took some 14ga metal bent a 90 degree and placed it tight against the roof with a 1/2" bead of seam sealer and pushed it against the roof to aid in expansion. It is clamped into place waiting for the sealer to cure. Then I'm going to tack weld it to the cross bracing before removing clamps.
Re: 33 chevy
Reply #56 on:
July 12, 2015, 07:24:21 PM »
That looks nice too, I liked FATnLOW's also. That was my thinking on the braces, I was thinking silicon gasket material, but seam sealer would work as well. Good job guys!
Re: 33 chevy
Reply #57 on:
July 13, 2015, 11:32:55 AM »
I did mine almost exactly as 62131 did his.
Re: 33 chevy
Reply #58 on:
July 14, 2015, 09:26:15 AM »
Went out and sprayed my DTM primer on.....But only put on One light coat,,,Ran out of primer...guess I was to excited to get it in primer..oh well at least it wont rust....now off to buy more....
Last Edit: July 14, 2015, 09:29:56 AM by FATnLOW
Re: 33 chevy
Reply #59 on:
July 14, 2015, 10:45:38 AM »
That looks really good! Nice work!
3
4
5
6
48
Miscellaneous
33 chevy
