1932 Pontiac Six build
45
46
47
48
60
Topic: 1932 Pontiac Six build (Read 698959 times)
Reply #675 on:
November 01, 2022, 02:46:18 PM »
I love summit. Ordered yesterday, parts came today.
Reply #676 on:
November 01, 2022, 05:06:35 PM »
I have visited their store front in Georgia, it's a warehouse with a store front, you can touch and look at all the items they have in their catalogue,
Reply #677 on:
November 10, 2022, 11:50:47 AM »
Few pics of the progress so far. That crossmember has to go. Painted it grey before installing.
Reply #678 on:
November 10, 2022, 02:05:44 PM »
Looks like a good fit with little modification's needed
Reply #679 on:
November 10, 2022, 03:52:38 PM »
COOL!
Reply #680 on:
November 10, 2022, 04:08:08 PM »
Looking good! I bet it will be a fair bit luxier and quieter at high way speeds with that transmission.
Reply #681 on:
November 10, 2022, 04:44:07 PM »
Nice work! That'll be so much nicer on the hi-way!
Reply #682 on:
November 12, 2022, 07:28:33 PM »
New x-member arrived. It says 5" drop but more like 4" . Cause the pad is welded at a angle. The bar itself is 5, so I'll cut and reweld the pad.
Also a bit of mock-up. The plan is to cut the driver's side near the pad and extend it 3.25" . This should clear the master cylinder by putting the bends under it.
The trans needs to come down 1.25" to be near where it was. Right now the pan is sitting on the original crossmember.
Reply #683 on:
November 12, 2022, 09:01:26 PM »
I used the same cross member, what I did was cut to the width I needed then welded flat stock on the ends drilled holes through the flat stock bolted it to my transmission with a floor jack set tranny at the right height drilled and tapped my frame rails, i used 1/4 plates in that area of my frame when I boxed it, Wish I had pictures to show you
Reply #684 on:
November 13, 2022, 08:38:50 PM »
Today's progress.
Bracket came off and re-welded in the proper position.
Triple/quadruple checked the measurements and started with the chop saw.
Tomorrow tack and mock-up.
Reply #685 on:
November 14, 2022, 07:20:55 AM »
Don't have a picture but for my 33 Chevy I turned one of those universal cross members upside down and welded another loop across the bottom.
In your situation you could turn it upside down and weld in a drop down square framed lower support.
Last Edit: November 14, 2022, 08:31:09 AM by EDNY
Reply #686 on:
November 16, 2022, 09:27:39 AM »
1st mockup went well. It clears the master cylinder and just need to move up the proportioning valve up a tad. It's a 1/2" short so I'll cut another tube to weld in.
Reply #687 on:
November 19, 2022, 03:23:19 PM »
Looks like it will go together nicely. The parts mocked up on the cardboard like that look good, just missing the welds.
Reply #688 on:
November 20, 2022, 11:52:12 AM »
Been so cold here I haven't gone out to the garage. 🥶
Reply #689 on:
November 20, 2022, 02:12:45 PM »
It is supposed to get up to the mid 30s today but it is sunny. I have to throw rocks out of the road for the propane truck that is supposed to come this week. They don't like getting rocks stuck between the dual tires. It's just two miles.
45
46
47
48
60
