Author Topic: 1932 Pontiac Six build  (Read 698954 times)
« Reply #390 on: September 24, 2017, 09:08:33 PM »
I went to harbor freight and picked up a set of offset box end wrenches. Had to cut 6" off the 19mm for it to fit in the frame.
Couldn't budge the bolt with the wrench so I took a hammer to the shock itself to break it loose.
Made alot of progress.
Sure wish I could post pics.  :-\
« Reply #391 on: September 25, 2017, 10:55:13 AM »
back plug , get to it.  I had a 67 cougar 390 that the back plug was nuts to get too.
 Either use a few universal wiggly joints , tried that,  or as we ended up doing , using a hole saw to get a socket thru the fender well and onto the offending plug.
Absolutely everything on that car was tough to get to.
mike       8)
« Reply #392 on: September 25, 2017, 11:32:53 AM »
Try working on a Bobcat. The only thing accessible is the fuel filler cap. I'm selling mine to keep me from torching it.
Rat at least you didn't have to ruin and real tools.
 Mike, my mom sold the '60 Sunliner and bought a Cougar. I quit doing her tuneups.
« Reply #393 on: September 26, 2017, 01:42:53 AM »
the 289 was easy to do, the 390--427--428 big block was as tight as hell.
Wonder what the guys who were racing these cougar / mustangs did at the track. ???? a 7 plug change.
« Reply #394 on: October 25, 2017, 10:11:25 PM »
Hmmm.
« Reply #395 on: October 31, 2017, 05:22:39 PM »
Long story short but removed the ride control and now have modern shocks.
« Reply #396 on: November 01, 2017, 09:52:20 AM »
Looks great! Well worth the 'cyphering.
« Reply #397 on: November 01, 2017, 12:43:45 PM »
Nice work!
« Reply #398 on: November 01, 2017, 06:42:27 PM »
How does it ride. Were the old units single action, only dampen in one direction?
« Reply #399 on: November 01, 2017, 07:51:45 PM »
Rides much better. Not getting the bouncyness like before. I think the old units were single action, would only work on rebounds not compression.
I may pull one more leaf from the pack but I want to see what improvements radials do.
That's the next mod.
Bye, bye whitewalls.
« Last Edit: November 01, 2017, 07:54:04 PM by Rattiac »
« Reply #400 on: November 02, 2017, 10:35:57 AM »
I have another broken spring on my '53 pickup. I have broken several of my "slimmer" sets, but it is a pickup and so used and it travels a rough road.
« Reply #401 on: November 02, 2017, 02:07:07 PM »
Maybe try lowering the psi in your tires to help take the shock out of the bumps. If your running 35, go to 30. It helps on the gravel roads.
Just to give you an idea;;;; off-road I run down to 18 , maybe more depending on how hardcore the trail or length.
But im sure you truck bed is full of gear so airing down may not be an option.
My neighbor works for AAA spring if ya need any spring work done LMK .
« Reply #402 on: November 06, 2017, 09:09:00 PM »
So, this happened.
Year I was born and just the other day.
« Reply #403 on: November 07, 2017, 07:15:44 AM »
Very cool 8)  Glad to see you're racking up some miles!
« Reply #404 on: November 07, 2017, 04:12:18 PM »
Mile Stones...as apposed to Miles Stoned :o
