Author Topic: 1932 Pontiac Six build  (Read 698942 times)
« Reply #360 on: July 01, 2017, 02:13:02 PM »
Rattiac, i'll be following :)
« Reply #361 on: July 01, 2017, 06:17:52 PM »
Me too, thanks for posting :D
« Reply #362 on: July 07, 2017, 07:23:03 PM »
I rolled the top up on the car. First time doing that since I've sewn it up. Maybe a night drive is in order.
« Reply #363 on: July 26, 2017, 12:28:54 AM »
Waiting to be mounted. The darkness is approaching.
 :o
« Last Edit: July 31, 2017, 11:36:41 PM by Rattiac »
« Reply #364 on: July 31, 2017, 11:44:30 PM »
New taillights are in. LEDs are gone.
Our best guess
A diode had failed and resulted in blown turn signal fuses.
I liked having the brightest taillights but I can't have this happen on a long distance trip, easier to replace a bulb.
I think the bulb lights look better in a way.
« Last Edit: July 31, 2017, 11:50:18 PM by Rattiac »
« Reply #365 on: August 05, 2017, 08:41:52 PM »
Alrighty then !
After new taillights, turn signal switch and HD flasher I think the electrical gremlin has been found.
Boy those taillights look sinister. ;D
Pic;;;; notice the blue wire. :o
« Reply #366 on: August 05, 2017, 08:47:03 PM »
Glad you found your gremlin....
« Reply #367 on: August 05, 2017, 09:06:28 PM »
Glad you got it figured out.
« Reply #368 on: August 06, 2017, 01:23:13 AM »
Saw one of these exhaust caps at a Ag store close by and was tempted to try it out.
Had to flip the cap around and reweld it to get it to work at this angle.
2nd pic is at idle .
« Reply #369 on: August 06, 2017, 06:07:10 AM »
Glad you found the problem!
« Reply #370 on: August 06, 2017, 08:45:32 PM »
Thanks. I went on a test drive . No blown fuses and all lights are working properly.
« Reply #371 on: August 07, 2017, 06:24:15 PM »
Alrighty then !
Glad you found the problem, the way you were describing it the switch almost had to be the culprit.
Kiwijeff
« Reply #372 on: August 13, 2017, 10:39:14 AM »
I've just whizzed through the whole thread, don't remember if I ever looked at it before.
A lot of pics are not working at the start,  but there's enough at this end.
Very cool Pontiac, I'll keep checking in, cause I know there's a burn out vid coming. ;D
« Reply #373 on: August 13, 2017, 06:22:40 PM »
Looks like I need to fire up the computer and fix those pics.
Thanks for letting me know.
« Reply #374 on: August 15, 2017, 12:18:14 AM »
I have the first 3 pages fixed.  8)
Hopefully tomorrow I can knock the rest out.
