Author Topic: 1932 coach build  (Read 241414 times)
Re: 1932 coach build
« Reply #105 on: July 13, 2015, 03:05:32 PM »
62131  I have the same problem,  I am not sure what to do with mine  I was thinking of stainless steel piano hinge after I cut out all the old stuff that is rusted tight  lol  I Like your idea  the wife and I are still wandering  we are ion Bad River Wisconsin  vette59jdwl
« Reply #106 on: July 13, 2015, 04:43:43 PM »
vette59jdwl  there's a  company that I call on that makes a hinge real similar to the original, they use it in the product they manufacture, I'm sure they will let me have a few sets if your interested if you decide to replace it. I had already made my mind up that I wasn't going to run the side panels until the boss showed up out in the garage  gave me her opinion, so I came up with this ideal and this way we both get what we want., ;D ;D ;D
« Last Edit: August 02, 2015, 06:35:29 PM by 62131 »
« Reply #107 on: August 02, 2015, 05:46:41 PM »
Here's what I came up with for the hood and how I'm going to make the sides removable.
« Reply #108 on: August 02, 2015, 05:50:22 PM »
Here's a few more with it assembled
« Reply #109 on: August 02, 2015, 06:38:30 PM »
Here's how I mounted my radiator in the shell.
« Reply #110 on: August 02, 2015, 07:06:16 PM »
That's some nice clean fabrication all around. How far off the ground is the bottom of your battery box?
« Reply #111 on: August 02, 2015, 07:28:13 PM »
Very nice work ;D
« Reply #112 on: August 02, 2015, 07:57:09 PM »
I really haven't measured but I do know it's well above the scrub line
« Reply #113 on: August 02, 2015, 08:33:47 PM »
What radiator is in your '32 ??     Following your hood  build... I like the concept of having removable sides...  Good  work....
« Reply #114 on: August 02, 2015, 08:46:40 PM »
I was just curious. It looks good there.
« Reply #115 on: August 02, 2015, 09:08:50 PM »
I purchased a CC3132 from Champion, removed the Ford mounting taps on the sides and made my own brackets lined with rubber for vibration. Hope it will do the job, They say it's good up to 800hp.  I've mounted the condenser in front of it and I plan on using a 16" pulling fan with 2700cfm.
« Last Edit: August 02, 2015, 09:34:12 PM by 62131 »
« Reply #116 on: August 03, 2015, 07:47:05 AM »
I have two of those radiators, have one in my 33 Chevy (TPI SBC) and using a Taurus 2 speed pull fan, the Taurus shroud fit like it was made for it.
Have one on my son's 37 Chevy sedan (LT1 SBC) and because of clearance used a Derale 17" fan #18217 (2400/1800) as a pusher, but can be used as a puller. The Derale fit just right.
The 33 Chevy hasn't been on the road..but the  radiator easily keeps the car cool around the yard and idling. Just got the 37 running last week and the LT1 fan from the factory doesn't kick on until 226 degrees!..so far so good.
« Last Edit: August 03, 2015, 07:52:17 AM by EDNY »
« Reply #117 on: August 03, 2015, 09:43:51 AM »
I used the same radiator in my '32. I have a mechanical fan with a universal fan shroud. All this summer it has gone over 180.
« Reply #118 on: August 03, 2015, 05:21:52 PM »
Ed   Do you remember what year Taurus you took the fan out of?  I like the ideal of a two speed fan.
« Reply #119 on: August 03, 2015, 08:29:23 PM »
Don't remember the year Taurus but they are rated as 2800/4500 CFM. What I like is that it fit that radiator like it was made for it. If you search the Internet you'll find a lot about that fan, here is one link (there are others):
  http://www.go.jeep-xj.info/HowtoTaurusFanInstall1.htm
If you get into a bind..I have an extra one only in case I secure another project ::).
BTW: Wanted to use one on my son's 37 sedan...but the Taurus fan is a puller and we didn't have the space..so had to go with a Derale pusher.
« Last Edit: August 03, 2015, 08:32:57 PM by EDNY »
