  • Total Topics: 2,997
  • Online today: 21
  • Guests: 4
  • Total: 4
4 Guests, 0 Users
1932 coach build
Started by 62131, October 22, 2014, 09:38:06 PM
I especially like that gauge panel. Is that from another car or did you fabricate that yourself?
Chopper  I ran across that panel at a car show, a vender must have had it for a while as the package was all faded and dirty. My plan is to have it hydro dipped in a bough walnut pattern.
Here is a picture of my grille insert in the shell, got that installed today
I purchased a Vintage Air A/C and Alternator mount and installed that today. Beware that this unit is not set up to be used with a after market intake original equipment only. Vintage Air does not list this anywhere. Took a little modifying and several hours to get it to line up.  If you look to the left of the ac unit you see my cowl vent motor that I talked about in a previous post. Will try and get a better picture.
Quote from: FATnLOW on April 06, 2016, 09:29:55 PM
62131.....Which cowl unit did you go with?? and  does it operate ok??   pics if you have them...
Here's a better picture of the cowl vent motor I came up with. If I knew if we could post a short video I show it in operation.
Nice set up, looks great!
Thought is was about time I come check out all your guy's builds. Awesome stuff going on here.
Looking at page 1.
I like the wood replacement in steel . Is there any other structure behind the sheet steel ?  Any other pics?
Also did you add any bracing to the fiberglass rear fenders.? I think I may go that route.
62131 It looks clean and all fits within the confines of a real hood  great  job   vette59jdwl
I've been spending some quality time in the garage here lately getting a lot of things done. Yesterday I completed my exhaust system, and put my drive shaft in. I have the wiring harness installed and been making termination as I complete sections of the car. I did bump the engine over the other night it won't belong before she will be coming to life :) :)
62131  Summer is upon us Its time to make a positive difference  sounds like you have your shi#! together going to be a nice ride  can not wait to see it rolling  congrats  vette59jdwl
Hey vette59jdwl you still interested in the hood? I just have not gotten it weighed to check the freight, I have been putting a penetrant on the hinge pins so that I can take it apart to make the package smaller.
 I have put more stuff on mine and i cant get it to budge so good luck with that one  OH by the way please send a pic or two to lave@cogeco.ca  thanks  vette59jdwl
oh its moving on the pins, just trying to get it were I can remove them easily
Vette,, are you trying to remove the pins from the hood panels????  Mine  were really  tight..what I did was sprayed  with them down with a penetrate( WD 40  or what ever you use)  and let the set  for 1-2 hrs... then took my propane torch and  heated the  pins and pin clamps   then let it  set over night ....then repeated this process again..and then took a drift rod( same size as the pin rod) and hammered the pin out until I was able to get vice grips  on the  pin... then hammered the vice grips and sprayed the pin as it was moving...this worked for me
Quote from: FATnLOW on May 13, 2016, 09:49:55 PM
That's pretty much how I did it except without the heat
