Author Topic: 1930 Buick V12 build  (Read 587725 times)
« Reply #330 on: April 14, 2024, 03:12:37 PM »
Thank you Ed!
I got a couple small things done, I sanded the distributor housings with  first 80 grit, then 180-360-600-
1000-2000 and 4000. it took just a few minutes to get them shiny after that.
I have new seals and gaskets in the distributors now, all bolted up with new hardware, new rotors and caps.
Last night I painted the gold stripes on the valve covers, and today my son was here, he sat in the kitchen
painting the CADILLAC script.
Just now in the evening, I screwed the valve covers to the heads with brass acrorn nuts and washers after
drenching the cam shafts in a liberal dose of stp.
Now I'm thinking about how to paint the air filter housings. Silver hammer varnish  is what they have been,
but maybe they should be black as not to add too many colors. They'll probably get an Air Maze fiter sticker
anyway, that's probably enough color.
« Reply #331 on: April 14, 2024, 08:54:11 PM »
Essex great job. Looks fantastic!👍👍
« Reply #332 on: April 15, 2024, 05:20:03 PM »
Looks great!
« Reply #333 on: April 18, 2024, 08:37:30 PM »
Black air filter would look awesome, not sure what air maze stickers look like. The cadillac valve covers are the best!
« Reply #334 on: April 20, 2024, 09:45:53 PM »
Wow!
« Reply #335 on: April 20, 2024, 11:40:34 PM »
That is nice.  Like the lil details,  brass nuts, ect.  👍
« Reply #336 on: April 25, 2024, 02:58:39 PM »
Thank you all, for the support and kind words!
chopper526 After pondering to and fro, I decided to paint the air filter housings black, and did it today.
This is what the Air Maze air filter sticker looked like (bottom), and the top one is my own redesign. I tried to
"Americanize" the Brittish filter sticker, just for fun.
I'll still have to order the sticker, but that's what it will look like. Just noticed that I have a typo there.
Yesterday I jacked up the body, still sitting on its dolly, to be able to do some welding that I couldn't do while
the frame was still bolted to the floor. To be done is finish welding a lot of rosette welds along the trans tunnel
and some details around the bottoms of the B-pillars.
The bottom edge along the rear of the body has some rust along it, so it needs some repair work done.
« Reply #337 on: May 11, 2024, 06:56:59 PM »
My project seems to have come to a standstill. Funny, since I've been at it like usual.
The body has been welded all along the trans tunnel and around the B-pillars, like I
mentioned earlier. A bright light inside the car and welding from the underside, I found
a wealth of small holes and misses in my welds, and also a few places where the work
wasn't quite finished. The bottom part of the rear end of the body still to do before
primerig the underside.
A few days went into designing, some shopping for materials and making an ignition
wire holdup thing. The ignition wires need to be held with something, since they run
above the exhaust headers. This design utilizes the original loom inside a
rectangular pipe.
When I got it in place, I thought it looked awful big and didn't like it. Even painted, and
decorated with brass acorn nuts, it looks too bulky to me, so I tried a simpler approach,
which I like better.
I made these things from nylon and they hold the ignition wires nicely and scurely. They
are held together with M3 screws and nuts, I think about #5 - 40 size. This is what's
holding the wires to the unpainted pieces of flat bar in the above pic.
are held together with M3 screws and nuts, I think about 5-40 size. The plastic looks
very light gray here, because they're sanded with coarse sanding paper, but it's
actually black nylon.
« Reply #338 on: May 13, 2024, 04:52:55 PM »
Nice! That should work well!
« Reply #339 on: May 15, 2024, 10:27:40 AM »
You say stand still, looks like progress to me. That little stuff has to be done to move on more important things. Looking good.
« Reply #340 on: May 15, 2024, 02:38:43 PM »
Thank you TFoch, I like the more mechanical look of the open ingnition wires, and that they look orderly
when pulled straight.
Thank you also, sammons. I guess even if it doesn't feel like it, it's progress as soon as you spend time
on the project. Sometimes it just doesn't feel productive, what you do.
I got mail yesterday, a nice size parcel, which contained a radiator. I tried it in its new place today, and even
if it's for a model A, it fits fairly well.
I cut out a 47"x9" piece of sheet metal, which will be the biggest patch I've ever made. I'm going to a friend's
shop one of these days to roll it in the english wheel.
There's some rust in the lower part of the rear of the body, where a filler panel between the fuel tank and the
body has been.
The plan is to repair the rust damage, and lengthen the body downwards about 3"  I figure the body would
otherwise look very short and odd, since I've just deleted the tank and not replaced it with anything.
« Reply #341 on: May 19, 2024, 02:58:34 PM »
As I mentioned in my last post, I was going to do a large patch, here's how it went.
I had made templates from wood and wood screws, to have something to check the
shape of the sheet against while I was rolling it.
Back at home I measured the new sheet centered and level and fastened it with four
sheet metal screws in lieu of clecos.
Then a lot of shrinking in the deep throat schrinker-stretcher. When the shape looked
okay, I made a 3/4" flange using a tipping die in the bead roller, then
shrinked the flange to get back to the right shape.
Having watched a lot of Fitzees Fabrications videos on youtube, I had long thought about
trying his cut-n-butt method. I did now, and it worked a charm. I cut some, then made a tack,
cut some more, made a tack and so on.
The body was extended downwards as far as I had made the new wheel arches three years
ago. Turned out it was two inches, not three as I mentioned earlier.
« Reply #342 on: May 21, 2024, 01:18:48 AM »
I need to do this to the rear of mine.  Being a 4-door it has a belt-line around the bottom and goes up by the rear fenders  around a corner.  Gonna take a pro to pull that off.
« Reply #343 on: May 26, 2024, 02:19:44 PM »
Rattiac, I watched Fitzee on youtube today, working on a custom fifties chevy (might acctually be a 1950),
 he does anything with simple tools. Maybe you don't need a pro, there's always bondo. I used 36 lbs of bondo
on my Essex, and it didn't even have fenders. It was my first project in the dream garage I had just built. I fail
to see my own limitations, sometimes it goes well, sometimes, not so much.
I had to get a small alternator, as  the one I had meant to use wouldn't fit. This is a 40 Ampere one, meant for
a Kubota. I had planned on using V-belts, but thought the better of it, I'll never get this build done, if I am
going to alter everything, so instead I bought a new pulley, and a 15-17 mm bushing to make it fit the axle.
Of course the pulley was too thick for the short axle, so I had to turn it down about  three thirtyseconds
on my uncle's lathe for the nut to have enough threads. It's never as easy as it looks.
It took me all weekend to make a sturdy alternator mount, that gets the pulleys exactly in line with
eachother. I admit to have been to town, shopping for a belt and having an ice cream too, so not actually all weekend.
« Reply #344 on: May 27, 2024, 03:43:04 PM »
Back panel looking good. Your making great progress.
