Author Topic: Oil pressure  (Read 12938 times)
David Galvin
Oil pressure
« on: April 14, 2014, 12:05:51 PM »
I bought a 1935 Chevy Standerd over the winter, It has original engine and has 15 lbs oil pressure when cold and after driveing for 1/2 hour it is at 2 lbs, I am thinking on changing oil and useing staight weight 30. I noticed what might be a screen where the oil pressure line comes out I will investagate. Any Ideas on this.
Re: Oil pressure
« Reply #1 on: April 14, 2014, 08:15:38 PM »
This is what the recommendations and normal pressure was from the original  Chevy maintenance manual for your engine.
David Galvin
Re: Oil pressure
« Reply #2 on: April 15, 2014, 01:32:29 AM »
I used seafoam on the engine, drained , put 15-45 in with a zink addative. 12-15 cool and 5-7 warm @45 mph had it going 60 but at idel when warm I am at zero, is this OK or do I need a pump.
Re: Oil pressure
« Reply #3 on: April 15, 2014, 07:38:01 AM »
My .02...if you are using the dash gauge...you might want to try an external gauge first?
Re: Oil pressure
« Reply #4 on: April 15, 2014, 09:55:25 AM »
 When my 32 was stock it would show 0 pressure at an idle when fully hot and I never had a problem. I went with the pressure reading at speed like the manual stated. If you want to read an interesting article about the early Chevy splash system take a look at this link
http://www.canadianmilitarypattern.com/Pattern%2012%20Engine%20Page%20Two.htm
