Author Topic: 33 chevy  (Read 587398 times)
Re: 33 chevy
« Reply #270 on: May 12, 2017, 05:52:09 PM »
Yes....352  hp range  and   in the low 400 fp torque...
Steve had a well known engine builder in this area that does a lot of  drag strip  and roundy round  motors ...Shinook  Engine builders in Tahlequah Ok....was going to go with aluim. heads but decided against it...I am satisfied with  the numbers...but not in my jingle account...but it's  ready to run.....
Re: 33 chevy
« Reply #271 on: May 12, 2017, 06:37:04 PM »
Ed my phone wouldn't load the movie but just seen your first pic. I think i've heard that name before, at least it sounds familiar.  My little 301 might get close to that hp number if I wind it tight enough. ;D Uncle said they were turning them 9-9.5  at the dirt track in the early/mid 60's. :o
Re: 33 chevy
« Reply #272 on: July 15, 2017, 07:46:10 PM »
Trying to get back on the '33...took 700R tranny to get rebuilt.. Then have to modify trans cross member...then might be able to install motor and trans ....if the wife doesn't have any more honey dos ..
Re: 33 chevy
« Reply #273 on: July 17, 2017, 08:08:58 PM »
Looking forward to the updates :D
Re: 33 chevy
« Reply #274 on: July 18, 2017, 01:40:00 PM »
Ed it's good to here your getting back to it, you should be real close to it moving around on it's own. :)   Wish I was, thinking of moving my coupe down to the shop for long term storage till I get back on my feet  . Keep at it man! :-\
Dang COE hood/grill got complicated, grill fit is done but having to build new hood edges  and inner structure due to the thing being so split up and twisted out of shape everywhere.
Re: 33 chevy
« Reply #275 on: August 01, 2017, 05:25:43 PM »
700r4 trans...cleaning it up a little...then remake and relocate trans cross member
« Last Edit: August 01, 2017, 05:32:05 PM by FATnLOW »
Re: 33 chevy
« Reply #276 on: August 05, 2017, 02:03:18 PM »
Getting g a few things done ..trans mount work and gonna join trans to motor...hope to have it installed by  Wed. If all goes well....
« Last Edit: August 05, 2017, 02:18:39 PM by FATnLOW »
Re: 33 chevy
« Reply #277 on: August 05, 2017, 05:01:58 PM »
Go Ed Go! :D
Re: 33 chevy
« Reply #278 on: August 17, 2017, 05:40:07 PM »
Finally some progress......had to refab trans mount for the 700r4...worked out perfect ...motor and trans fell into place....
« Last Edit: August 17, 2017, 08:09:45 PM by FATnLOW »
Re: 33 chevy
« Reply #279 on: August 17, 2017, 08:47:14 PM »
Fits like a glove!  Looks great Ed!
Re: 33 chevy
« Reply #280 on: August 17, 2017, 10:18:42 PM »
Nice fit, Ed, the steering too.
Re: 33 chevy
« Reply #281 on: August 20, 2017, 01:15:06 PM »
Had these Ram Horn headers from a build that I didn't use ...so I put them on the '33...problem is now the spark plug wire holders don't bolt up to the valves covers as the ram horns are in the way...so I thought of mounting them like this....now I have to make sure the wires don't hit the headers and burn up...is there any kind of insulation that is available that will slip over the spark plug wires? Don't want any thing that wraps on the wire....and again I my not have an issue with hitting or being close to the headers ...what you think if the way its mounted?....might just change the wires out and route the wires differently and not use the holders
« Last Edit: August 20, 2017, 01:28:19 PM by FATnLOW »
ChevRon
Re: 33 chevy
« Reply #282 on: August 20, 2017, 02:15:29 PM »
      I run mine behind the head then down below the rear exhaust port and  come up to the plugs. Run the front two down  next the oil pan and use the oil pan bolt with adel clamp to keep them away from the collector , then run the front two  up thru and behind the engine mount. (Between the block and back of engine mount.) I try to hide as much wiring as I can. Hope I explained well enough. Ron
Re: 33 chevy
« Reply #283 on: August 20, 2017, 04:06:55 PM »
Your engine looks real nice Ed.   I've used both these Speedway spark plug wire insulators on various builds, especialy with headers.
Like Chevron said, run them underneath. The 60s stock Chevy routing, here is a pic. I've done this on most that I have stock type exhaust manifolds on and on my coupe as the sprint car headers pretty much go straight out for 10-12" before turning down.
ChevRon
Re: 33 chevy
« Reply #284 on: August 20, 2017, 04:20:51 PM »
  Thanks sammons, couldn't find a picture.
  FATnLOW definitly nice looking engine. Ron
