Author Topic: 33 chevy  (Read 586993 times)
Re: 33 chevy
« Reply #435 on: November 21, 2018, 07:25:19 PM »
Steve...plans are to upholstery with Ultra Leather, with some kind of design and inset .... Using two colors that go together...I have a picture as to what I want.Will post when I find it
Re: 33 chevy
« Reply #436 on: November 21, 2018, 07:47:21 PM »
couldn't find photo of door panels but  possibly colors something like this...still along way from this point
Re: 33 chevy
« Reply #437 on: November 22, 2018, 12:08:17 PM »
Cool, that should work. Have a good Turkeyday Ed!
Re: 33 chevy
« Reply #438 on: November 30, 2018, 01:45:44 PM »
Well Velcro doesn't work as I thought it would..sticks well to the plastic but not well at all on wood or steel...changed up fastners...
« Last Edit: November 30, 2018, 02:21:54 PM by FATnLOW »
Re: 33 chevy
« Reply #439 on: December 03, 2018, 01:35:18 PM »
Too bad the velcro didn't hold. Nothing wrong with trim screws, easy to use and they don't break off R&R the panels ;)
Re: 33 chevy
« Reply #440 on: December 04, 2018, 10:43:40 PM »
Screws look just fine. For what it's worth, I used newer style door panel clips. The heads get covered over by whatever you use for upholstery.
Re: 33 chevy
« Reply #441 on: December 05, 2018, 10:01:08 AM »
The way around the non stick Velcro  too wood , would be to nail or small screw a material that the velcro will stick to , in the correct locations.  Problem solved ???
Re: EFI
« Reply #442 on: January 09, 2019, 03:35:29 PM »
Re: 33 chevy
« Reply #443 on: January 09, 2019, 06:38:59 PM »
I'll let you know.  I ordered this one.  Should be in sometime next week.  Everyone I spoke to that has one was very happy with it.
https://www.summitracing.com/parts/fif-38003
Munch installed the one you're looking at.
Re: 33 chevy
« Reply #444 on: January 09, 2019, 07:30:49 PM »
Thanks..keep me updated....and I will get in touch with munch....I see that this one does not require a fuel return line and is good for the 150-400 HP range.....
Re: 33 chevy
« Reply #445 on: January 09, 2019, 07:53:46 PM »
Doesn't require the return line to the fuel tank but make sure you have room for the Fuel Command Center that you'll have to mount in your engine compartment.  I've attached the instructions below.
ChevRon
Re: 33 chevy
« Reply #446 on: January 10, 2019, 09:22:49 PM »
Tom .. If you run a fuel command center.... you need to  put it somewhere cool. These things are notorious for boiling fuel. With it being in the engine compartment plus the short run from throttle body to command center the fuel heats up. I had that problem on the first one I did . Ended up running return line.  Just a FYI.. Ron
« Last Edit: January 10, 2019, 09:31:52 PM by ChevRon »
Re: 33 chevy
« Reply #447 on: January 10, 2019, 09:34:57 PM »
I looked at the 3 different ways to install the FITech in my 33 and decided on using the in tank pump.  I spoke with quite a few guys that installed it on their rides and all were happy with it.  The main reason I went with the in tank pump is noise.  With a topless car I was worried that the noise from the fuel pump would bother me.  I spoke with @Munch on here who installed an external pump in his sedan and he said the pump wasn't that loud.  I did't pick the Fuel Command Center as my engine compartment just didn't have the room.
ChevRon
Re: 33 chevy
« Reply #448 on: January 10, 2019, 10:34:55 PM »
 Yep. That's the best way. In tank pumps are pretty quiet.  Usually with the engine running you barely hear it. Ron.
Re: 33 chevy
« Reply #449 on: January 10, 2019, 11:41:53 PM »
Appears that the "fuel command center" works similar to the system in a diesel...the diesel low pressure "lift pump" delivers fuel up to the engines "injection pump".  In a carb'd engine the original low pressure fuel pump just delivers fuel to the fuel command center.
The diesel engines in my mid 90's GM trucks had a fuel return lines that were plugged and not used and I noticed that the lift pump was located in the exact same location as the metal fuel filter would be on a gas engine. Figure GM just ran both supply and return lines just to keep things simple and could be adapted on the assembly line for either a gas or diesel engine.
When I do my TPI and LT1 EFI conversions I learned to use only ACDelco inline pumps, the other aftermarket units are noisy.  Just try to mount the pump on some rubber and if possible close and lower than the tank.  Prefer the in tank pumps..best way to go.
