Author Topic: 33 chevy  (Read 587282 times)
Re: 33 chevy
« Reply #120 on: November 13, 2015, 09:20:39 PM »
FATnLOW I did not see that in the first pics  I thought maybe you were going to use the old chevy truck hold down or the new rubber block with the 10mm screw that holds the battery into the box  either way looks  cool   vette59jdwl
Re: 33 chevy
« Reply #121 on: November 13, 2015, 09:43:38 PM »
FATnLOW nice progress!  Great work on the battery box.
Re: 33 chevy
« Reply #122 on: November 14, 2015, 05:33:35 PM »
been working on wiring...made a swing open panel cover and installed Peel and Seal  for sound deadener
That should keep it hid good!  ;)
Re: 33 chevy
« Reply #123 on: November 14, 2015, 06:56:50 PM »
That's what I thought it was, I used it in my 38, at first I was concerned about the asphalt smell from what I had read . It doesn't have any at all. That's what will go in my 32
62131.. Did you use peel and stick on the floor??  Been thinking about using it on the floor and especially on the tranny hump and around the floor shifter. May use it on the inside of the doors rather than the bubble wrap...any opinions??
Yes I did, I covered the whole floor pan and even the trunk area, I even did my doors and kick panel area. I never had any smell of asphalt at all, I know one thing once it's down it's stuck
Re: 33 chevy
« Reply #124 on: November 14, 2015, 09:25:22 PM »
62131...Thanks for the info....
Re: 33 chevy
« Reply #125 on: November 15, 2015, 10:47:20 AM »
Man you are moving along with your car. I like everything you have done to get it to this point.
Re: 33 chevy
« Reply #126 on: December 03, 2015, 06:16:37 PM »
Need some inspiration..... Working my on dash...I would like to see photos of other dashes and consoles either on the floor or over head....have an idea in mind but wanted to see photos of your dash.
   Haven't been doing much of anything with the 33 since I  have to re make A/C pods.. need to get inspired and motivated again
Re: 33 chevy
« Reply #127 on: December 03, 2015, 06:30:22 PM »
All I have is the black walnut behind the gauges from the tree I had to cut down to build my garage.  I plan to do something with the heater controls at the bottom to match the gauges.  I don't have AC so I can't help you there.  Here's a couple of pics.  Hope you get your inspiration back.  You're at a point that each thing you get done gets you even closer to that first ride.  Keep up the great work!
Re: 33 chevy
« Reply #128 on: December 04, 2015, 10:18:22 AM »
FatNlow, me too! I need the old man to come back and ride my a$$ like he use to on these projects! ;D  He never let grass grow under my feet for sure.
Re: 33 chevy
« Reply #129 on: December 04, 2015, 12:08:23 PM »
Sorry, FATnLOW, but I have nothing for you. My dash is plain-Jane and I don't even have all the gauges yet. Add that to Christmas coming up and I don't see too much time or money invested in my car until after the new year. :'(
Re: 33 chevy
« Reply #130 on: December 04, 2015, 05:42:45 PM »
Sammons.....Gonna  make the same style  of A/C pods like on your build.... But I feel that I need a  short  dash extension  to kinda tie in the a/c pod on the passenger side and a console for radio and some floor vents for the A/C  and what ever else that I need to put there.  The only obstacle I have is that I still want to use the cowl vent, so I will have to have some kind of opening in the console to access the handle. The drivers side is ok as the A/C pod meets the column  drop....So looks like i'll be making a lot of patterns from card board until I  like what I see.  I have a vision in my head of what I want now just getting it in a card board so I can build it
Re: 33 chevy
« Reply #131 on: December 04, 2015, 05:58:23 PM »
Ed, i ended up making an electric vent opener. Does your handle mount more to the center(like a 34 std), or to the outer drivers side? Reason i ask is i beleive i still have a 34' master LH mount handle that you are welcome to. It may move it futher the left to give a little more console area room.
Here is a pic of my old '34master with the handel installed. I wish i had a head on pic because this pic angel makes it look too far to the left.
« Last Edit: December 04, 2015, 06:26:52 PM by sammons »
Re: 33 chevy
« Reply #132 on: December 04, 2015, 06:34:58 PM »
  You know there is a electric cowl vent motor kit that can be purchased? I have found a little  12vdc gear motor and plan on making my own as I do not have enough room for the manual lever because of my a/c unit. The gear motor I found is like 2" Sq. and 10 rpm which if I did my math correctly it should open or close the vent in 3 seconds.
Re: 33 chevy
« Reply #133 on: December 04, 2015, 07:35:34 PM »
Sammons...My handle is in line with the left hole of the 3 that  are above the spears...I believe that if I move it to the drivers side I might get really close to my Tach gauge... and I looked at some linear actuators and found out that they are to large
 Steve.. Thanks for the offer if the cowl motor does not work out I may take you up on the unit
  If you have any more info on this cowl vent motor kit, dealer that  sells it I would greatly appreciate the info. This could be the ticket out of my vent problem
« Last Edit: December 04, 2015, 08:37:51 PM by FATnLOW »
Re: 33 chevy
« Reply #134 on: December 04, 2015, 09:28:35 PM »
Fatnlow  It is offered thru Watsons Streetworks their part number L34 complete kit, motor only L34m.
