Author Topic: 33 chevy  (Read 587223 times)
Re: 33 chevy
« Reply #105 on: October 25, 2015, 05:46:52 PM »
Mike, I don't know…."Why ??  Because I have no interest in them."  :)  Now if it was a '25-'28 Chevy 4 cylinder I'd pay attention. It's great that we don'e all like the same stuff there wouldn't be enough to go around. 8)
Re: 33 chevy
« Reply #106 on: October 25, 2015, 06:25:54 PM »
Mike they look like Toyota  they are to square to be Mazda   vette59jdwl
Re: 33 chevy
« Reply #107 on: October 25, 2015, 07:31:54 PM »
nope the 16 valve rocker covers are not for any furren car, they are for a v8
while looking for another picture of them I came across this one. Its got a relocated distributor to front drive, the carbs are Ferrari on some weird intake manifold, toss in those 16 valve covers and mass confusion reigns  !!
And these valve covers fit ?????? a XXXXXXX motor
« Last Edit: October 25, 2015, 07:50:59 PM by madmike3434 »
Re: 33 chevy
« Reply #108 on: November 04, 2015, 06:44:45 PM »
 After looking at the planned location of my fuse panel ,finally got it mounted by turning it 90 degrees...also got all the wires in their right location, motor section, headlight section ,tail section  and interior section,,using a Hay Wire fuse  panel first time to use this,  got this on sale a few years ago at  NSRA event,,Usually install  Ron Francis kit...but this one seem t compare to it, wire is  marked every 6 inches and marked very clearly, and has a lot of circuits that I will not use such as  power windows,,power seats , clock , park lights and a few others
Re: 33 chevy
« Reply #109 on: November 04, 2015, 10:00:26 PM »
FATnLOW,  where did that end up being at?  Do you happen to have a pic?
Re: 33 chevy
« Reply #110 on: November 04, 2015, 10:06:55 PM »
The valve covers are 2 piece and made by the GENNIE SHIFTER COMPANY, they fit small block chevy.  I have these on my 350 in 35 coupe.  People are always looking at them trying to figure out what the motor is.
There was another 2 piece valve cover made that was 7" wide also, LARSON ENGINEERING.  Made about the same time early 80's .  The larsons show up on ebay usa more frequently and sell anywhere from $400 to $1500 depending on condition.
Re: 33 chevy
« Reply #111 on: November 05, 2015, 09:52:56 PM »
Mounted fuse panel  here..was suppose to be higher but brake assembly crowded my space..as it is mounted accessing the fuses will be easy.. no contorted positions to get to the fuse box...
« Last Edit: November 05, 2015, 09:54:28 PM by FATnLOW »
Re: 33 chevy
« Reply #112 on: November 13, 2015, 02:57:44 PM »
been working on wiring...made a swing open panel cover and installed Peel and Seal  for sound deadener
Re: 33 chevy
« Reply #113 on: November 13, 2015, 03:02:39 PM »
Still have to mount  a piece of flat steel on the uni-struts so A/C can be mounted on to it.....also mounted battery box still need to fabricate a top and front side for it...
« Last Edit: November 13, 2015, 03:14:37 PM by FATnLOW »
Re: 33 chevy
« Reply #114 on: November 13, 2015, 05:24:02 PM »
Fatnlow  i like your battery holder  i just don't see your holddown  vette59jdwl  lookin good
« Last Edit: November 13, 2015, 05:35:24 PM by vette59jdwl »
Re: 33 chevy
« Reply #115 on: November 13, 2015, 05:59:48 PM »
    Vette.....Angle iron (look at the bottom front) held in by the 2 bolts ,,angle iron hold down goes  on outer edge of battery
  Photos  not the battery I am going to use...Will use  Group 42 battery  Length 9.31 inches by 6.31 inches by 6.31 inches
   I am going to cut the battery box down to accept the group 42 battery..    Battery in box is for mock up only.. Photos  of angle iron hold down
« Last Edit: November 13, 2015, 06:19:28 PM by FATnLOW »
Re: 33 chevy
« Reply #116 on: November 13, 2015, 07:28:04 PM »
Fatnlow what sound deadener did you use?
Re: 33 chevy
« Reply #117 on: November 13, 2015, 08:39:35 PM »
62131...
I used Peel and Stick  seems to take the tinny sound out of the fire wall, hope it knocks  the heat down also..   I still have the old style firewall insulation if the heat and sound is  an issue I'll install that also.
Re: 33 chevy
« Reply #118 on: November 13, 2015, 08:45:15 PM »
That's what I thought it was, I used it in my 38, at first I was concerned about the asphalt smell from what I had read . It doesn't have any at all. That's what will go in my 32
Re: 33 chevy
« Reply #119 on: November 13, 2015, 08:58:28 PM »
62131.. Did you use peel and stick on the floor??  Been thinking about using it on the floor and especially on the tranny hump and around the floor shifter. May use it on the inside of the doors rather than the bubble wrap...any opinions??
