Author Topic: 1932 Pontiac Six build  (Read 698716 times)
« Reply #810 on: April 17, 2024, 02:09:28 PM »
Was going over the wiring.  Couldn't get the big plug to connect,  had to do some sanding to the edges to fit right.
Spring finally hit here,  so I hooked up the trailer and went out to the Pony express trail in search of the wild horse herd . Camping at Simpson Springs.  All I found was 3 horses scattered across the valley range.  Stars were spectacular though.  Helped a guy broken down but his was a catastrophic trans issue.  Missing dipstick.
He had a ride coming and eventually a tow truck showed up before dark.
This weekend is yard work.  Hopefully back to the car next week.
« Reply #811 on: April 20, 2024, 11:12:50 PM »
Today after yard work I got the turn signals wired up.  Then the plug painless supplied wouldn't click together.  Tried the other and it fit just fine, so I swapped the wires over to that.  Luckily with this lil tool I could get the wires to release easily.
Maybe ignition switch and neutral safety switch tomorrow.
« Reply #812 on: April 22, 2024, 12:46:12 AM »
After some yard work I spent most of the day in the shop.
Pulled the ignition switch out of the dash and slowly started rerouting , transferring wires and soldering them together.
Plugged the battery back in and put the key in and fired right up  .
A few things left before I hit the road.
Get wires back under dash
See why horn doesn't work.
Tighten up steering wheel adapter
Remove floor shifter,  cover hole in floor
Remove toeboard
Bend brake pedal over a tad.
Remove clutch pedal.
Oh, the ignition key hole will be replaced with a cigarette lighter/usb  charger.  Just happened to be the perfect size.
« Reply #813 on: April 22, 2024, 11:57:40 AM »
Great progress. Good to see someone getting somewhere!
« Reply #814 on: April 23, 2024, 12:01:57 AM »
Feels good to actually get something done.
After work I adjusted the neutral safety switch,  had to hog out the screw holes and get it as far left as I could.  .  Messed with the 2 wire horn button.  I just needed to ground the 2nd wire and use one of the bolt holes in the adapter.
Might be able to drive it to work next week.
« Last Edit: May 04, 2024, 04:25:37 PM by Rattiac »
« Reply #815 on: April 23, 2024, 07:05:14 AM »
Great!  Glad you're making progress!
« Reply #816 on: April 25, 2024, 03:03:39 PM »
Sounds good! Nothing like getting to drive a car with a nice upgrade.
« Reply #817 on: April 28, 2024, 07:06:48 PM »
Removed the old shifter and clutch pedal. Goodbye Imortan Joe shifter knob . 😦
Looks and feels a bit more roomier.  While I was at it.  Mounted the lil tach farther down the column and somewhat hidden.  I still need to do indicators for the turn signals but I hear it clicking for now.
Took it for it's 1st test drive since the column swap.  I like this smaller steering wheel and still good with a manual steer car. 😎
« Reply #818 on: May 03, 2024, 08:05:23 AM »
Looks great with the new wheel and column. I think I'd like it there. Thumbs up!
« Reply #819 on: May 03, 2024, 04:28:59 PM »
Lookin' good!
« Reply #820 on: May 05, 2024, 10:44:49 AM »
Looks good indeed.
« Reply #821 on: May 05, 2024, 07:48:06 PM »
That's looking good, keep moving forward!
« Reply #822 on: May 06, 2024, 07:18:57 AM »
gauges look great
« Reply #823 on: May 30, 2024, 02:05:19 PM »
I made another YouTube channel just for the 32.
Named it "32 Pontiac Six" to easily find.  Transfered the older videos to there and have a few new upcoming videos to release.
@32PontiacSix-rk6vs
« Reply #824 on: June 08, 2024, 03:04:50 PM »
While im waiting for my fingers to heal I've been doing all my steel measurements.  Made a drawing on some cardboard.
I picked up 24ft of 1.25" but I'm not sure why I did that.  I'll need to get 16ft of 1.5" and I can use the smaller stuff for bracing and walls.
The 1.5" will be for the top main rails.
Rear seat and floor are already out previously.
