Author Topic: 1932 Pontiac Six build  (Read 698947 times)
« Reply #480 on: September 11, 2019, 10:41:00 PM »
Test drive complete and very happy with the new rear leafspring's. 😎
Sits up a bit higher in the back now. 👍
The only thing I need now is some modern shocks back there.
« Last Edit: September 11, 2019, 10:43:15 PM by Rattiac »
« Reply #481 on: September 12, 2019, 07:08:57 AM »
Looks good!
« Reply #482 on: September 22, 2019, 08:57:22 PM »
Im glad it's not sagging on that side anymore.
Seems to handle better and stay straight in the lane.
3rd brake light is wired up and looking great.
I thought about going to a 2" LED but I think this is subtle.
Starting to tear out the rear floor right now.
« Reply #483 on: September 25, 2019, 08:09:01 PM »
Looking good! You're not wasting any time.
« Reply #484 on: September 25, 2019, 08:17:51 PM »
Thanks Chopper.
New parts are in. 8)
Monroe air shocks for a 1980 Chevy Malibu and the parallel air line kit from summit racing
Rear upper shock bar for 35-40 Ford
Lower shock mounts adjustable , both from speedway.
The bar is a 43" width and the frame
is near 40-1/2" wide.
« Last Edit: September 25, 2019, 08:19:30 PM by Rattiac »
« Reply #485 on: September 25, 2019, 10:14:07 PM »
Looks like it'll do the trick!
« Reply #486 on: September 26, 2019, 02:07:48 PM »
Goodbye old "ride control" system.
These were toast. One side worked only on rebound and the other worked only on compression even with new oil.  :o
« Reply #487 on: October 02, 2019, 09:52:20 PM »
Since I have the rear floor out, I think im going to "re-do" the sub-framing while im in there along with more reinforcement to the seat mounts.
Wasn't happy with that. :-[
« Reply #488 on: October 03, 2019, 02:29:30 PM »
Looks more like "ride out of control"! You are going to love those new shocks!
« Reply #489 on: October 03, 2019, 02:56:22 PM »
Just think of the car as a "continuous work in progress", they are never done.  Always bugs to peel off, oil to change and the occasional wash and wax ,  even if just in primer.
mike..................HAIRBALL
« Reply #490 on: October 13, 2019, 08:47:03 PM »
Was able to get the shock bar in easily. The frame gets wider in the rear.
Now the exhaust, brake and gas needs to be moved.
Measurements.
20.5" -- extended
12.75" -- collapsed
7.75" -- travel
Axle has 5.75" uptravel before bumpstops.
The bar is mounted as high as I can get it in the frame.
With the lower mount at it's lowest position I'll have 4" downtravel left on the shock at ride height.
I may have to add a 1" bumpstop.
Also I need to space out the shock on the lower mount.
It's a bit close.
« Last Edit: October 13, 2019, 08:55:06 PM by Rattiac »
« Reply #491 on: October 14, 2019, 02:42:19 PM »
I accidentally kinked the fuel line trying to get it out of the way and started leaking gas. 😠
So it'll be a week or so before I can do any welding.
« Reply #492 on: November 15, 2019, 02:05:49 PM »
New shock studs are in. These will be perfect.
« Reply #493 on: December 15, 2019, 08:32:42 PM »
It's been a few months. All aired out now.
So after trying different things and measuring over and over.
Today, with 2 fire extinguishers near me, I made some tack welds on the upper shock bar.
Used some 6011 to reduce the sparks. Seems to help.
I need to throw a few practice vertical welds before I burn it in permanently. It's been awhile.
« Reply #494 on: December 15, 2019, 08:52:21 PM »
Just a thought.  I mounted my cross member behind the differential so the top of the diff wouldn't hit it depending on suspension travel and for more exhaust clearance.
