Author Topic: 400 SBC Motor with HEI failure  (Read 3596 times)
RoarsRods
« on: December 30, 2020, 06:18:19 PM »
My 1933 Ford 3 window coupe winter start up with a 400 SBC Motor!
Just a question with these HEI Modules!
I have been having a lot of failed modules! Been using both MSD modules and Acell modules and both brands have been failing!
My thoughts are possibly I just might need a in-line HEI Battery feed resistor!
Any thoughts on what’s causing this failure or what is the best way to resolve this problem?
Thanks in advance!
Here’s a YouTube video link:
https://www.youtube.com/watch?v=-NJKEDmJcDI
Re: 400 SBC Motor with HEI failure
« Reply #1 on: December 30, 2020, 07:29:20 PM »
This is a very informative discussion and should help:
http://www.superchevy.com/how-to/1306-upgrading-a-points-distributor-to-an-hei-system
BTW: I'm sure you are using the white heat sink (thermo-grease) compound (and not dielectric grease).
« Last Edit: December 30, 2020, 07:45:08 PM by EDNY »
RoarsRods
« Reply #2 on: December 31, 2020, 08:49:48 PM »
Thanks Ed very interested article! Thanks and yes I always use the white heat lube! I had posted this HEI Control Module question on several Ford and Chevrolet Facebook hot rod sites! I believe it is my alternator regulator is bad with surges over 15.5 V causing my control module to fail! So now am having it rebuilt! Here’s my new control module and my Facebook comment!
RoarsRods
