80
81
82
83
97
Topic: What Did You do Today - Car Related? (Read 1048375 times)
Reply #1200 on:
September 22, 2022, 06:35:48 AM »
Yep I had a 64 coupe and ended up selling it
Reply #1201 on:
September 23, 2022, 01:31:08 PM »
The linkage that was hitting the header controls the neutral safety switch, backup lights and locking steering wheel, I can't disable it. So, I did what I had to do and bashed my new ceramic coated header :'( I whacked it good and the linkage still brushes against it when I put the shifter in 1st gear. I'm leaving as is and see how it goes, I'm afraid if I hit it anymore I will split the steel at the weld
Reply #1202 on:
September 23, 2022, 02:48:57 PM »
Whoo that hurts one's feelings
Reply #1203 on:
September 24, 2022, 12:36:25 AM »
Sometimes things just don't fit without some persuasion. (hammers)
Last Edit: September 24, 2022, 11:33:14 AM by sixball
Reply #1204 on:
September 29, 2022, 02:08:52 PM »
As the wrench turns.... here's where I am at on my son's Camaro. Got the power steering pump in and took a chance ordering a new pressure line for a '78 El Camino, it worked perfect. Started it up, put it in gear...nothing. I forgot to put fluid in the trans!! Put in fluid, started it up...it all leaked out the cooler lines I forgot to tighten!!!
That's the problem sometimes, with long projects, you forget what you did and didn't do.
Anyway, we are going to pull it out of the garage any minute now, fingers crossed. However, here is my new dilemma: I am using the same radiator and clutch fan that was on the 6cyl., my research says they were used on both 6's and 8's, the problem is the fan is about 4 1/2 inches from the fan and way outside the shroud. Any thoughts?
Reply #1205 on:
September 29, 2022, 02:18:05 PM »
Incidentally, it has a long water pump. I am starting to think maybe there is a difference between the shrouds on a 6 and 8 cyl.?
Reply #1206 on:
September 29, 2022, 05:19:15 PM »
Long strung out projects.....yep. You forget where you were.😁
Chopper the 6 was a longer engine, fan shroud was shorter. Get a v8 shroud or measure how long a fan spacer you need to get the blade back into the 6 cyl shroud. I'd guess at 2" - 2-1/2" spacer.
Reply #1207 on:
September 29, 2022, 08:35:51 PM »
Thanks Sammons, I think I am going to try an 8cyl. shroud. Looking at it, a spacer won't work on the clutch fan because the clutch is in the way of using long bolts.
Reply #1208 on:
September 30, 2022, 07:46:08 AM »
Chopper get yourself some threaded studs and thread those into the pump flange then slide your spacer on then the clutch fan, apply the nuts, just a thought
Reply #1209 on:
October 01, 2022, 11:31:09 AM »
Why didn't I think of that ?!
Thanks, good idea. Sometimes I think I overthink things
Reply #1210 on:
October 01, 2022, 04:04:06 PM »
sometimes you just have to step back and think about it awhile
Reply #1211 on:
October 08, 2022, 09:01:22 PM »
Took a ride and the fall colors are starting to pop!
Reply #1212 on:
October 08, 2022, 09:38:42 PM »
Pretty!
Reply #1213 on:
October 09, 2022, 10:42:04 AM »
A seat from this week. 65 chevy truck bench.
Reply #1214 on:
October 09, 2022, 02:54:20 PM »
Nice! My '68 needs that! My '53 needs help too. All my pants have holes from a broken spring.
80
81
82
83
97
