Author Topic: Headlight Buckets  (Read 6785 times)
Headlight Buckets
« on: September 09, 2015, 03:23:07 PM »
I have a set of 1930 headlight buckets that I got from Ghost, and have been reworking them.  Looking pretty good.  I think I may have found a set of trim rings and lens, but want to make them modern lights.  I guess I might get lucky and find a 9 1/4 sealed beam that would fit but have not yet.  Does anyone have any suggestions for converting them to usable lights?  All I have is the buckets now, and took out the original bulb socket because of corrosion.
Re: Headlight Buckets
« Reply #1 on: September 09, 2015, 04:28:39 PM »
  MUNCH...I have some head light adapters...but nothing for your 9.25 inch opening..attached are some photos...FYI
Photo 29  outer ring goes around 7 inch seal beam then into the adapter
« Reply #2 on: September 09, 2015, 06:27:28 PM »
Munch,
This is what I did on my 33.  http://rustybowtie.com/index.php?topic=797.0
« Reply #3 on: September 09, 2015, 06:48:40 PM »
There's is a H4 socket conversion kit that you can by from Speedway that might work for you.
« Reply #4 on: September 09, 2015, 09:50:48 PM »
Check with the 30-31 ford headlight conversions. They might be the right size or really close
« Reply #5 on: September 10, 2015, 05:51:14 AM »
Did a little checking on the diameter of  seal beams, they are measured in 1/8" being a Par 74 is what you need to obtain the 9.25 dia. seal beams are a parabolic aluminized reflector or "PAR"     9.25 divided by .125 = par74
« Reply #6 on: September 10, 2015, 07:51:35 AM »
Thanks guys, I thought about the conversion units but do not have the reflectors.  I need to track some down.  62131 where do I find the par74?
« Reply #7 on: September 10, 2015, 08:21:45 AM »
Good morning munch. The ford conversions I am referring to come complete with the reflectors that will mount the new hallogen bulbs in them.
« Reply #8 on: September 10, 2015, 11:43:19 AM »
  Thanks Ghost, I will look them up.
« Reply #9 on: September 10, 2015, 01:14:19 PM »
  Ghost,
The ones I see have 8 1/2 inch reflectors, are you saying they could be mounted down in the bucket?
« Reply #10 on: September 10, 2015, 03:36:25 PM »
  I can't seem to find anything larger than a PER 64.
« Reply #11 on: September 10, 2015, 09:17:54 PM »
  Ghost,
I don't know about that, but if they are too small the 32 ford buckets are a larger unit. worth a look
« Reply #12 on: September 11, 2015, 11:26:11 AM »
  Ghost,
  Ghost,
I found a conversion set for a 32 and the reflectors measure 9 1/4, sure hope the fit.
Thanks Ghost
« Reply #13 on: September 13, 2015, 04:12:49 PM »
Sorry for the delay in my response just returned home from Shades O the Past car show. I can't help you with where to find them just added that info so it would give you something to search with.
« Reply #14 on: September 14, 2015, 07:02:13 AM »
  Thanks, hope you had a great time...
