Author Topic: '28 headlights  (Read 22019 times)
trbomax
'28 headlights
« on: March 21, 2014, 08:21:08 PM »
I am starting a new topic for this discussion.I want to apoligise for hijacking the "got piggy" thread with my headlight discussion.
I called aaa this morning and talked to eddie,who wanted a pic of my reflecter with a measurement on it.He said that 7.5" seemed too small for a 28 unit. I tod him it came on the car in 1958 when I got it and had all the bowtie emblems on it too. Anywhay,here is what I sent him.havent heard back yet but will keep all informed.
Re: '28 headlights
« Reply #1 on: March 21, 2014, 10:53:33 PM »
I'm interested in some for my headlights too. The price is a lot better than the local plater!
Are your lenses clear?
trbomax
Re: '28 headlights
« Reply #2 on: March 21, 2014, 11:19:38 PM »
 The lenses are 8-11/16" dia clear glass.
Re: '28 headlights
« Reply #3 on: March 22, 2014, 03:40:02 PM »
Here are the pics of what I did.  I started with the original reflectors and cut the middle out of them.  Then attached the new reflectors to the old reflector rims with 4-40 screws as shown.  Everything fit right back in the original headlight buckets.  They measure 8 1/2" across.
trbomax
Re: '28 headlights
« Reply #4 on: March 22, 2014, 04:28:40 PM »
Did you get the dual bulb reflecters from aaa?
« Last Edit: March 22, 2014, 04:32:25 PM by trbomax »
Re: '28 headlights
« Reply #5 on: March 22, 2014, 05:48:00 PM »
Yes it was Part # A-13027-QK12TS
Re: '28 headlights
« Reply #6 on: March 22, 2014, 07:39:40 PM »
Oboy, is that ever slick!  Thanks a million!
trbomax
Re: '28 headlights
« Reply #7 on: March 23, 2014, 09:38:56 PM »
 Does haveing the amber bulb in the reflecter mess with the light pattern? I am going to do it your way unless eddie comes up with a bolt in reflecter.What did you do with the bayonett connecter on the back of the houseing where the wireing comes thru?I was thinking hole saw that out and put in a rubber grommet,then run all 3 wires inside a piece of ss braided hose,do the same in the fender with a larger grommet that a 3 prong plug would fit thru.
Re: '28 headlights
« Reply #8 on: March 24, 2014, 12:24:47 AM »
Tom, that looks like a great solution.
Re: '28 headlights
« Reply #9 on: March 24, 2014, 07:45:33 PM »
I have seen these with the amber bulb on cars but never asked if it affected the light pattern,  I pried the connector off of the housing (carefully) with a screwdriver. Right now I have a rubber grommet in there but I haven't mounted them on the car yet.  I plan to get some type of conduit and seal it to the housing and then run the wires to the grill.
trbomax
Re: '28 headlights
« Reply #10 on: March 24, 2014, 09:13:06 PM »
Thats what I was talking about with the houseing. If you have a Parker or AeroQuip store close by, they have rubber hydraulic hose with a stainless steel braid over it. i was going to get a couple pieces that fit the grommet and just run the wires inside it. Put a couple zip ties on the inside so id doesnt fall thru.The 3 wires should fit nicely inside a #4 hose.
trbomax
Re: '28 headlights
« Reply #11 on: March 24, 2014, 09:17:35 PM »
Re: '28 headlights
« Reply #12 on: March 24, 2014, 09:26:32 PM »
Speedway has a pair of wire conduit with pretty good reviews for $34.99.  Might be cheaper the way you mentioned.
Re: '28 headlights
« Reply #13 on: March 24, 2014, 10:48:47 PM »
They look pretty nice, and reasonably priced as well.  Definitely something to consider.
trbomax
Re: '28 headlights
« Reply #14 on: March 25, 2014, 12:13:20 AM »
 With those fittings on the ends,they are BETTER than what I was going to do! You guys sure know how to spend other peoples money!
