Author Topic: New Guy From Saskatchewan  (Read 13978 times)
Chemong55
Re: New Guy From Saskatchewan
« Reply #15 on: December 15, 2014, 08:35:02 AM »
Here is a Link to more pictures of my build
http://s1122.photobucket.com/user/chemong55/library/
« Reply #16 on: December 15, 2014, 09:33:20 AM »
What I have done on the 27 and 28 chevy is cut the nails off with a thin blade cut off wheel, then drill and counter sink holes every so often,  I install the pieces with small screws, or nuts and bolts  straighten the trim as you go, and body work as needed over the screws heads. mine was below the windshield.
« Last Edit: December 15, 2014, 09:36:27 AM by ghost28 »
Chemong55
« Reply #17 on: December 15, 2014, 09:45:30 AM »
Thanks I had thought of doing that just wasn't  sure if body fill would crack around screw heads
« Reply #18 on: December 15, 2014, 11:23:23 AM »
Yes , you would have to assume that bondo body filler would crack and separate from the aluminum strip.
I might think about dipping the screw into a silicon caulking and wiping off the excess on the aluminum strip.  That would give you a seal on the screws.  To reduce the chances of leaking, do not put any more holes into the aluminum strip than is already there.
just my 2 cents thoughts
mike........... 8)
Chemong55
« Reply #19 on: December 15, 2014, 10:39:50 PM »
Just checked bindi specs and says it bonds to aluminum
letalley1
« Reply #20 on: January 16, 2015, 07:53:55 PM »
Chemong55,
You may want to check out  letalley1's build thread on his 1930 Chevy Coupe.  He has pics of that seam.
http://s106.photobucket.com/user/letncat/1930%20Chevrolet/story
Chemong55,
I drilled through the nail cover over each nail, removed the nails, installed with screws (shot silicone in each hole then screw), counter sunk each hole, filled with JB Weld.  JB Weld adheres to to aluminum (and any other metal I've tried it on), but not to to the masking tape used to hold it in place till it dries.  That's what all the little patches you see in the picture are about.  I see ghost28 does the same thing.  The JB Weld has been in there going on 10 years without a single crack.
« Last Edit: January 16, 2015, 07:59:57 PM by letalley1 »
Chemong55
« Reply #21 on: January 17, 2015, 07:36:15 AM »
Thanks that explains it very well
