Miscellaneous
'35 standard 3w build: hopefully
12
13
14
15
30
Topic: '35 standard 3w build: hopefully (Read 456110 times)
Reply #180 on:
December 29, 2014, 10:02:25 PM »
Sammons,
Nice work on those tail light buckets! Nice material for the crash bars. I used a Vintage Air Heater/Defroster in my 33. Very happy with it and great technical support.
Reply #181 on:
December 31, 2014, 10:37:19 PM »
Thanks Tom, I sure like them.
I really hated to cut down this nice grill shell, but that's what I got it for. I had to take 5 1/2" out of it. 1" lower on top and 4 1/2" raised on the bottom ( didn't ever want to scrape it on anything). Now i don't have to wonder what to do with the crank hole in grill. Maybe tomorrow i'll get my radiator mounted so I can fit the grill shell.
Reply #182 on:
January 01, 2015, 11:09:40 AM »
Nice work on everything. How big is your radiator gonna be?
Reply #183 on:
January 01, 2015, 11:38:18 AM »
Thanks Ghost, the radiator is 18"w x23"t aluminium 4 core.
Reply #184 on:
January 02, 2015, 02:08:16 PM »
Decided to mount the radiator as low as possible in the crossmember. It has quite a bow to it, so I cut two notches yesterday. I got the box's made, fit, and welded in.
Went down to the auto parts store(where my last job was. My friend owns it, he's the one I recently laid out the flames for) and picked up two exhaust manifold spring sets for the lower mounts. Dang I resigned almost two years ago and he still sells me parts at store cost!
I welded the studs to the underside of the box's so I don't have to fiddle with reaching up in the crossmember. So now to find some rubber cushions for the mount tabs, so I can set it. Next will be to get the grill shell fitted.
Reply #185 on:
January 02, 2015, 05:16:23 PM »
Nice and clean. Your grinder looks just like one that I have. The damn thing will hurt you if your not carefull.
Reply #186 on:
January 02, 2015, 06:10:24 PM »
Yep Ghost, bad-fast they'll hurt you! Been there. It really got my dad years back. He lost his grip, caught an edge and got him deep in the wrist, tendons etc.
If I can't get a decent grip that day, I leave it be!
Got radiator mounted, lower anyway. The sway bar will fit behind. Now to figure mounts and shroud. I know in the pic the grill shell looks real high, but it sticks down 3" below the front speader and 9" off the ground. I plan on doing a little more lowering on the ride height after all the weight is added and it settles.
Reply #187 on:
January 02, 2015, 07:02:14 PM »
Sammons I like the way you notched your cross member to accommodate the lowering of the radiator and the grill shell, is it necessary to mount the radiator on springs since it will be mounted solid to the cross member? Will you be running a hood?
Reply #188 on:
January 02, 2015, 07:20:23 PM »
62131,
Dad always told me it was. He use to work in a radiator shop in his youth. He said that a radiator has to be able to move somewhat or it will stress crack at the mounting points.He always did, and so have I, and never had any problems.
Yes, i'll be running a hood. At least a top, i need to get it built. I want a few louvers in it and I have a guy in OKC that wants to buy my press. I also want to make side panels around the headers, and hopefully a belly pan, and It will need louvered if i do it.
I'll be cutting the rear lip off the grill shell to add on to extend the back side of it to cover the radiator. Think of it as kind of a track nose. Not for everyone, but that's what I want. I think I have figured out my nurf bars also.(side)
Last Edit: January 02, 2015, 07:45:10 PM by sammons
Reply #189 on:
January 02, 2015, 08:02:04 PM »
Sammons..
I'm using the same radiator and ran into the same "cross member" situation with the IFS on my 33 5W. Finally extended the hood 5" so I could position the rad down and in front of the Xmember.
Mentioned it before.....the car looks more like a (long) 33 Pontiac coupe now...would love to have a 33 Pontiac coupe!
Reply #190 on:
January 02, 2015, 08:10:21 PM »
Ed at least it gives me room up front, behind the grill . I want to build a "grill guard" inside it. It might save my radiator someday.
Yep, I like a longer nose anyway. The original 107" WB didn't do it for me, that's part of the reason I went with the Master 112".
Old Pontiacs are cool !
Reply #191 on:
January 02, 2015, 08:35:16 PM »
The reason I asked about the spring mounts is that your radiator shows side mounting tabs.
Reply #192 on:
January 02, 2015, 08:56:50 PM »
I think that's for universal mounting. It's got 2-bottom tabs, 4-side tabs and 1-upper center. I'm going to fasten the shoud to the side tabs, and shell (w/rubber) to the upper center.
I found my radiator under( model A copped 3") for chevy application. Ad said up too 750hp? It will either cool or it won't.
Reply #193 on:
January 02, 2015, 09:11:07 PM »
I believe I have the same radiator, haven't had it out of the in over 2 years. I believe the part number was ca3132 it to was for a Ford.
Reply #194 on:
January 03, 2015, 10:07:01 AM »
The radiator I usually buy is the 32 ford chopped 3 inches, but I think they are mostly the same.
12
13
14
15
30
Miscellaneous
