Author Topic: Wanted 34 Chevy Master frame  (Read 22035 times)
« on: December 30, 2012, 09:42:18 PM »
Wanted:  1934 Chevy Master frame without front or rear suspension ie framed rails. (Planning on boxing, installing a Mustang II and four link)
Prefer one close to the "very upstate New York" area.
Re: Wanted 34 Chevy Master frame
« Reply #1 on: December 30, 2012, 09:48:13 PM »
Progressive Automotive has frame rails with the cross members installed.  See below
Builder Frames
Our frames are produced from 10 gauge steel and double welded for superior strength. Full length boxing plates and our tubular X-member is installed. The X-member is designed to accommodate all short tail shaft G.M. transmissions, including the overdrive models. Front radiator mounts, body mounts, running board brace holes and vulcanized G.M. transmission mounts are provided..... CC2..............$3,940.00
http://www.progressiveautomotive.com
« Reply #2 on: December 30, 2012, 10:01:44 PM »
Thanks Tom...looking for a stock one so I can just put it away until I need it.  My 34 Master is a 1980's build, IE stick welded, not mig'd. Nothing wrong with it, but it even has an OEM Mustang II front end welded in!
I'd like to have one to set up at my convenience...then just swap the entire body/chassis instead of taking the 34 apart and having parts all over the place in various stages of completion.
Located a nice one in Canada for $200....but it's a long way up north!  Still might take a run up there in Spring.
« Reply #3 on: July 08, 2014, 10:36:10 PM »
Just giving myself a BUMP in case someone trolls the forum..
« Reply #4 on: July 09, 2014, 07:12:44 AM »
Saw another 33 frame on Ebay for cheap.  I'll keep looking for a 34.
« Reply #6 on: September 08, 2014, 10:52:03 AM »
Ed  I think i have solved your problem get in touch with of me off line at  lave@cogeco.ca.   Wayne
« Last Edit: September 08, 2014, 03:14:57 PM by vette59jdwl »
redsshed77
« Reply #7 on: December 30, 2014, 01:46:34 PM »
i just sold my 34 frame from a think a master model with my 32 body.buyer had no intention on using it and planned on selling it. hes in ri on mass border.
  frame was excellent and still had the factory date stamp visable on frame rail.originally came with the dubonnet independent suspension.i could get his info
« Reply #8 on: December 30, 2014, 02:48:33 PM »
That would be great..I'm only a 4-5 hrs from there.
« Reply #9 on: December 30, 2014, 02:54:51 PM »
Ed,
If you need help getting it let me know.  It's not too far from me.
« Reply #10 on: December 30, 2014, 05:31:50 PM »
Ed,
Thanks Tom..
redsshed77
« Reply #11 on: December 30, 2014, 08:03:16 PM »
i sent him a message.its available.i have a picture of it.is it what your looking for?
« Reply #12 on: December 30, 2014, 08:39:17 PM »
Looks like my 34....just need to determine if it's a 34 Master for sure. Got your PM with contact info.
« Reply #13 on: December 30, 2014, 09:01:57 PM »
redsshed77
Thanks for the info..just called him....let me just say he wants a lot for it.  Could buy a new boxed frame for a few hundred dollars more to give you an idea.
I know of one way up in Canada that I need to get serious about.
« Reply #14 on: December 30, 2014, 09:30:56 PM »
viewing pictures of that frame, I would say YES its definitely a 34 master.
I would say a good solid complete not rusted thru frame like this would be $300---500 range .
They built a lot of 1934 Chevrolet masters and frames should not be scarce.
The guy can ask whatever he wants, cannot eat RIDICULOUS ASKING PRICE.
The frame is missing the rear riveted to the frame, " gas tank cover support brackets" that are about 6==10 inches from the end.
MIKE============ 8)
« Last Edit: December 30, 2014, 09:33:39 PM by madmike3434 »
