Author Topic: Wiring My 33 Chevy  (Read 59100 times)
Re: Wiring My 33 Chevy
« Reply #30 on: April 23, 2014, 12:46:29 AM »
I wired the 700R4 Transmission to the switch on the dash.  I picked up a normally open switch and Omron #21911C relay.  I used the attached schematic to wire everything so driving around town and back roads the converter will not lock.  Then if I go on the highway and pull the switch, the converter can lock and will release when I touch the brake pedal.
I think I need to do this on my old Lumina van.  The wiring is currently disconnected, but if you hook it up the engine will stall when you come to a halt.  The switch would allow me to fix that annoying little problem and most likely give me better highway mileage as well.
« Reply #31 on: May 12, 2014, 08:34:41 PM »
Finally got the rear section of the floor in so I could run my wires out to the tail lights.  I ran them along the floor and then drilled a couple of holes in the rear part of the body.  I used rubber grommets anywhere the wires ran through sheet metal.  I crimped male and female connectors to connect the wires at the tail light so if I need to remove them it'll be easy.  Once I get the head lights and turn signals wired up front I'll test them.
« Reply #32 on: May 13, 2014, 12:23:50 AM »
Tom. all O have to say is you do nice work...reeeeaaaaal nice!
« Reply #33 on: May 26, 2014, 07:58:20 AM »
To finish up the lighting part of the wiring I ran the wires for the headlights and taillights.  As with all the other parts of the kit the wires were well marked.  The directionals and the parking lights each had their own wires for left and right and were connected to each side.  The headlights had one low beam and one high beam wire which I had to splice into to split it so I could connect to each light.  I soldered the connections and them used shrink sleeving to seal them.  I use connectors I could unplug if I want to remove the headlights for any reason.
« Reply #34 on: May 26, 2014, 07:59:01 AM »
The directionals and parking lights are in the headlight assembly and light up well.  The halogen bulbs light up good but we’ll see how they work when I get the car outside at night.
« Reply #35 on: May 26, 2014, 10:07:52 AM »
Very cool. Now is about the time I sit in the garage with the door down and the lights out just to enjoy the dash and headlights for awhile...John
« Reply #36 on: June 25, 2014, 09:30:57 PM »
The inside of your rear fender area is very close to a 1934-1935 standard design.
What I noticed and have a question about, the factory brace that runs across the underneath of the fender from the skirt area, to the inside close to body. There is a bunch of spot welds that have been drilled out. Have you shortened the factory brace to where it appears in this picture.
You may not know they exist,  but there actually is a stamped brace that goes in those 2 holes on the frame , just visable in your picture, and it connects the gas tank cover and the fender together. Its called a gas tank cover/fender support bracket.
Just thought you would like to know, as I only found out the parts existed a couple of years ago.
 mike lynch.... 8)
« Last Edit: June 25, 2014, 09:33:50 PM by madmike3434 »
« Reply #37 on: June 26, 2014, 07:19:33 AM »
 mike lynch.... 8)
Mike,
Good eye, this brace is on the passenger side and was damaged so I did shorten it.  I still have to attach the fender to the gas tank apron some how as the bottom of the fender vibrates too much.  Are the braces you talk about reproduced or should I be looking for an original?
« Reply #38 on: June 26, 2014, 09:33:13 AM »
Actually I did reproduce 50 of the 1934-1935 standard series braces. Had them cut out with a flow jet cutter and then used a brake to bend them for left and right.
I know 34 master is much different.  I think I had a picture of the 33 master one but no idea where it went too.  I was trying to find the listing for the part numbers in my 1940 parts book, but I cannot figure out what Chevrolet actually listed them as.
I will take a few pictures of the ones I produced and post the picture on here.
These are the pictures of the 1934-1935 chev standard series rear fender/gas tank cover support bracket that I had made.  Center to center on the 1/4" bolt holes in frame and bracket is 1 1/4"
I have looked everywhere for the 1933-1934 master pair I have, they seem to be out visiting somewhere,  despite repeated searches of their last known location.  The shape on the 33-34 type was much different than this, kinda like a half circle
« Last Edit: June 26, 2014, 11:28:44 AM by madmike3434 »
« Reply #39 on: June 26, 2014, 06:07:41 PM »
Once your gas tank cover is mounted using the 3 bolts on each of the sides, the cover is slotted,  and the rear fenders bolted to it, that will stiffen it up.  The brace attaches at the top bolt where the slot is.
Once you have all that fitted properly, check the bumper bolts chassis mount spacing too the gas tank cover. The cover should fit snuggly against them, if there is any slop , make spacers to take up the gap underneath , otherwise you will crush the area where it the bumper bracket is pulled against the chassis mount.
I would mount the gas tank cover panel with 4 bolts ( use button head allen heads ) that hold the gas tank cover too the frame crossmember, loosely . If you tighten these you will distort the cover panel unless its a perfect no gap fit .
I never liked the look of a spare tire mounted back there , personally.
If you could find a used one, I would look for the right rear inside fender brace.
mike lynch      8)
