Author Topic: super red ram  (Read 14069 times)
super red ram
« on: September 24, 2013, 08:33:19 PM »
Hey guys I just ran across a complete super red ram engine and transmission. Running when removed stored inside a garage.  Does anybody have any knowledge on this engine and what it would be worth?
« Last Edit: September 25, 2013, 10:19:03 PM by 62131 »
Re: super red ram
« Reply #1 on: September 25, 2013, 07:18:51 AM »
I did a yahoo search of "super red ram engine" and found a lot of informative history....but nothing with a value yet.
Here is one link discussing the Poly and Hemi:
http://www.hotrodders.com/forum/super-red-ram-poly-hemi-116672.html
« Last Edit: September 25, 2013, 07:20:27 AM by EDNY »
Re: super red ram
« Reply #2 on: September 25, 2013, 07:27:28 PM »
EDNY thanks for the link. I checked it out and found that what I have located is a Hemi not a poly the plugs go threw the valve covers. I think that it would be a nice little engine to have just for the rarity of it. I was told it only had 78k miles on it when it was pulled, I would like to find some information on how start an engine that has been setting for a while like this one.
« Last Edit: September 25, 2013, 10:20:15 PM by 62131 »
Re: super red ram
« Reply #3 on: September 25, 2013, 08:45:08 PM »
SequenceYearNameC.I.Carb. BBLH.P.
DESOTO:
S17 - 1001
1952
Firedome
276
2
160
S16 - 1001
1953
Firedome
276
2
160
S19 - 1001
1954
Firedome
276
2
170
S21 - 1001
1955
Fireflite
291
4
200
S22 - 1001
1955
Firedome
291
2
185
S23 - 1001
1956
Firedome
330
2
230
S24 - 1001
1956
Fireflite
330
4
255
S24A - 1001
1956
Adventurer
341
2-4
320*
S25 - 1001
1957
Firedome
341
2
270
S26 - 1001
1957
Fireflite
341
4
295
S26A - 1001
1957
Adventurer
345
2-4
345*
DODGE:
D44 - 1001
1953
Red Ram
241
2
140
D50A - 1001
1954
Red Ram
241
2
140
D50 (1, 2, 3)
1954
Red Ram
241
2
150
D553 - 1001
1955
Super Red Ram
270
2 or 4
183 or 193
D500 - 1001
1956
D500
315
4
260
KD500 - 1001
1957
D500
325
4 or 2-4
285 or 310
CHRYSLER:
C51 - 8 - 1001
1951
Chrysler
331
2
180**
C52 - 8 - 1001
1952
Chrysler
331
2
180**
C53 - 8 - 1001
1953
Chrysler
331
2
180**
C541 - 8 - 1001
1954
New Yorker
331
2
195**
C542 - 8 - 1001
1954
New Yorker
331
4
235**
WE55 - 1001
1955
New Yorker
331
2
250
NE55 - 1001
1955
New Yorker
331
4
250
CE55 - 1001
1955
Imperial
331
4
250
3NE55 - 1001
1955
C300
331
2-4
300***
NE56 - 1001
1956
New Yorker
354
4
280
CE56 - 1001
1956
Imperial
354
4
280
3NE56 - 1001
1956
300B
354
2-4
340***
NE57 - 1001
1957
New Yorker
392
4
325
3NE57 - 1001
1957
300C
392
2-4
375***
CE57 - 1001
1957
Imperial
392
4
325
58N - 1001
1958
New Yorker
392
4
345
58C - 1001
1958
Imperial
392
4
345
58N3 - 1001
1958
300D
392
2-4
380
* Very rare! All 4 BBL engines were approximately 10% of production.
 ** 1951 through mid-1954 have bell housings cast onto block.
 *** 300 High Performance Option
Re: super red ram
« Reply #4 on: September 25, 2013, 10:18:35 PM »
Moose  I found this chart, what I have located is a super red ram engine with 78k miles w/ auto transmission
and 2 barrel carb. stored in a garage complete from oil pan to breather. By the chart it is a D553-1001 I'm trying to find what it is worth.
Re: super red ram
« Reply #5 on: September 26, 2013, 08:52:19 AM »
There was one for sale here for 1500.00 without a transmission  http://www.jalopyjournal.com/forum/showthread.php?t=705629
Re: super red ram
« Reply #6 on: September 26, 2013, 08:28:26 PM »
The 270 red ram Hemi or baby Hemi as there known as. If you can get it started, and it runs good stock should bring in the neighborhood of $1.000.00 to $1,500.00 to someone building a cool little hot rod. As for making sure it turns over freely take all the plugs out and soak the cylinders with oil and let it sit and every once in awhile try to turn it with a braker bar on the front crank bolt or the flywheel .  Once it turns freely then start it if it will, it will smoke like a  diesel for a little while. GOOD LUCK
« Last Edit: September 26, 2013, 08:31:06 PM by ghost28 »
Re: super red ram
« Reply #7 on: September 26, 2013, 10:17:59 PM »
My intentions are to put oil in the cylinders remove the valve covers lube the rocker arms and push rods, change the oil after rotating engine the with a  breaker bar several time, remove distributor  and rotate oil pump and try to circulate oil if possible then try to start it.
« Last Edit: September 28, 2013, 10:17:30 PM by 62131 »
Re: super red ram
« Reply #8 on: September 27, 2013, 07:20:27 PM »
My intentions are to put oil in the cylinders remove he valve covers lube the rocker arms and push rods, change the oil after rotating engine the with a  breaker bar several time, remove distributor  and rotate oil pump and try to circulate oil if possible then try to start it.
Sounds like a good plan. I hope it runs for ya. They are neat little engines.
