Author Topic: need flywheel  (Read 13426 times)
trbomax
need flywheel
« on: June 15, 2013, 04:59:05 PM »
 i need a 454 external bal std shift flywheel. Must have a good gear and face,no heat cracked junk.
Re: need flywheel
« Reply #1 on: June 15, 2013, 06:04:51 PM »
By chance would you have a part number?
trbomax
Re: need flywheel
« Reply #2 on: June 15, 2013, 09:06:23 PM »
No #. The 2 motors I have are early 70's pickup truck,q-jet carb, but they were autos. It will be a starting point for the 28 chev build. I will be useing the bell housing and 4 spd  t-10 that was behind the sb because its a truck,open bottom set up for hyd clutch.
« Last Edit: June 15, 2013, 09:12:35 PM by trbomax »
Re: need flywheel
« Reply #3 on: June 15, 2013, 11:42:10 PM »
I have about 5 or 6 various flywheels (including new) I gathered over the years...but not sure what application they came from.  I'll try to do some research tomorrow.
Had a 400 SBC flywheel in the barn....thought they were externally balanced and might work.
« Last Edit: June 15, 2013, 11:45:26 PM by EDNY »
Re: need flywheel
« Reply #4 on: June 16, 2013, 12:28:47 PM »
trbomax
Re: need flywheel
« Reply #5 on: June 16, 2013, 07:50:33 PM »
Question at this point is how many tooth wheel do I need. I guess I could count the flex plate teeth and see what works. Only problem with that is that the motors are 300 miles south in my old shop!
Re: need flywheel
« Reply #6 on: June 16, 2013, 08:09:46 PM »
Someone may jump in...but I would think you want the 168 tooth unit, bigger and more clutch area.
The 153 tooth is smaller in diameter and I doubt they made one for the 454 anyway. The 153 is smaller in diameter, lighter and better suited for high rev engines.
I'm sure your 454 had a 168 tooth unit.....not sure which hydraulic unit you are using and if it's compatible.
« Last Edit: June 16, 2013, 08:15:52 PM by EDNY »
Re: need flywheel
« Reply #7 on: June 16, 2013, 08:59:57 PM »
The only size flywheel used on the production  454 was the larger 168 teeth version because of that needed extra weight on one side for balance purposes. Production engines never got the smaller 153 teeth flywheel. That being said I believe that there was an over the counter  153 tooth flywheel for the big blocks offered by GM that was 153 tooth but because of it's smaller diameter it required a smaller clutch and different starter. As Ed said your better off using the larger flywheel for a number or reasons. Depending on what bell housing you have you might want to check to make sure it will accept with the larger flywheel. Most will but from what I understand some will not
trbomax
Re: need flywheel
« Reply #8 on: June 17, 2013, 10:48:39 PM »
  I used this bellhousing in the car when it was a small block. Its iron,open bottom,and has the tapped holes for the clutch slave. It has the motor mounts on the side,but I didnt use them.I used a 11" clutch with it,so I must need a 168t wheel.
