Author Topic: The mundane valve stem....NOT  (Read 11974 times)
« on: May 21, 2013, 08:54:38 PM »
We tend to overlook the importance of some items that are usually are so trouble free that they hardly even enter into our thought process when planning and building a hot rod. One of those items is the valve stem. What could go wrong? Well as it turns out plenty. I was reading a post on the HAMB where a guy talked about his valve stems breaking off at the face of the wheel causing rapid loss of air resulting in a shredded tire and another one that failed a year earlier both form the same supplier The failure could have caused far worse problems...He was lucky. I did some research and found the attached PDF that talks about what you need to know these days when buying valve stems.
Re: The mundane valve stem....NOT
« Reply #1 on: March 01, 2014, 07:23:28 PM »
Never gave any of that a thought.  I think I have plastic valve caps too!
