Author Topic: How to easily cut neat round holes with a plasma cutter  (Read 11231 times)
« on: March 02, 2023, 05:17:54 PM »
I've cut holes in sheetmetal using plywoodtemplates, but the cutter head is hard to
get to move smootly. Using a thin slice of tubing welded to a piece of sheet metal works great.
In this case I used a slice of 2-1/2" exhaust tubing and welded it to
 a piece of sheet metal to get it clamped it to the work piece.
Holes are cut fast, and come out decently shaped.
There you go. Nice hole cut using a simple tool.
The size of the cut hole is a bit smaller than the inner diameter of the tube. The scribe
around the hole is the same diameter as the inside of the tube.
A plasma is a great tool if you do some fabrication.
Re: How to easily cut neat round holes with a plasma cutter
« Reply #1 on: March 05, 2023, 06:58:17 PM »
Nice tip Essex_29!
« Reply #2 on: March 06, 2023, 05:10:08 PM »
If you have access to a large assortment of pipes you could create a nice set of hole templates, what a great ideal
« Reply #3 on: March 08, 2023, 04:02:36 AM »
A few of those, and you could make neat lightening holes in defferent sizes fast.
