Author Topic: Door Panel Material And Thickness  (Read 34057 times)
« on: December 15, 2022, 09:20:31 AM »
I'm looking at making some inner door panels for my 33.  What material and thickness would you recommend?
Rattiac, any tips and tricks?
Re: Door Panel Material And Thickness
« Reply #1 on: December 15, 2022, 03:01:24 PM »
On my 38 I used panel board; I believe it was 3/16 thk, I purchased it from a local interior shop on my 32 I used a 1/8" luan 4x8 sheet that I found at a local lumber yard, they keep it for use on houseboat repairs
« Reply #2 on: December 16, 2022, 02:52:56 AM »
I used 3/16" plywood on my Pontiac. It's stiff, but not too stiff, and it's fairly easy to work
with. Also it takes staples well. 4 mm staples in my case.
When I got the holes for the crank and latch handle drilled I put the panel on the door and drilled holes for
generic plastic interior retainers. The ones I used had a big flat head, and the stem had like thin fins to keep
them in a hole. Like this:
So as the interior panel was held in its place, I drilled the holes through the plywood and into the door. Removed
the panel, then pushed the retainers into the plywood, stapled the door covering material on the panel, and then
just had to aim the retainers into the holes in the door, and give every retainer a bump with my fist. Very
straightforward, and no visible screws or such. I assume that kind of retainers can be found at your auto parts shop.
« Reply #3 on: December 16, 2022, 08:53:33 AM »
The christmas tree push pins Essex's is describing can be purchased in bulk off Ebay, there you will find a large assortment
« Reply #4 on: December 16, 2022, 09:11:52 AM »
We use the (black) panel board 3/16. I believe it's water proof/resistant.
If you can't find it the 1/8" Luan will do. You can use some clear plastic to set up to the door and draw out your pattern , mounting holes and such.
Lowe's has a decent selection of  Xmas tree clips  in various sizes.
« Reply #5 on: December 16, 2022, 10:43:57 AM »
Nix that....
My boss says the panel board isn't water resistant even though it says it is.
Using the laun or 1/8" wood will hold 1/8". staples better . You can always paint em for better water resistance.
Short decorative screws will work if you can't find the Xmas tree clips.
« Reply #6 on: December 16, 2022, 10:57:12 AM »
I found on my 38 where i used the panel board it would swell when it got wet, thats why i used the Luan on my 32 plus it was cheaper
« Reply #7 on: December 16, 2022, 04:24:41 PM »
My 33 being a convertible, Water proof or resistant would be important to me.
« Reply #8 on: December 17, 2022, 02:21:37 PM »
Nix that....
Rattiac...I have a Juki walking foot sewing machine...what backing material can be sewn with these walking foot machines?
« Reply #9 on: December 17, 2022, 07:40:27 PM »
1/8" ABS
« Reply #10 on: December 17, 2022, 09:23:43 PM »
A juki is what I use at work. You can sew up to 1/2" thick foams with backing, plus material.  Can sew on door board cardboard but if you start breaking needles then might have to get larger needles or might have reached the limits.
Very rarely do we sew onto door board.
We have a huge WW2 machine for the extremely thick stuff .
« Last Edit: December 17, 2022, 09:32:48 PM by Rattiac »
« Reply #11 on: December 18, 2022, 07:04:51 PM »
I used 1/8" mdf. You can wet it or steam it and bend it to curve. Once it dries it retains the curve.
« Reply #12 on: December 19, 2022, 10:40:32 AM »
Good tip chopper 526, I might try that. curved panels would look cool.
« Reply #13 on: March 06, 2024, 10:22:45 PM »
.  You can use aluminum sheet for door panels as well.  It needs to be cleaned with quick dry wax & grease remover and scuffed for any adhesive to stick to.
