1930 Buick V12 build
36
37
38
39
42
Topic: 1930 Buick V12 build (Read 565156 times)
Reply #540 on:
February 15, 2026, 10:28:43 PM »
Very nice work.
Reply #541 on:
February 16, 2026, 07:04:45 AM »
Essex, nice press job. That came out smooth! 👍
Reply #542 on:
February 20, 2026, 01:18:00 AM »
Thank you
and
I think I'll never be done, I welded a ton of pin holes in one of the
rear fenders last night. Picking up my own sloppy work.
One more fender to go, I did this on the front fenders earlier.
I made the little shelf that bolts to the inside of the fender yesterday,
With the 1/4" roundbar along the edge. Of course I noticed that I
had tacked the roundbar on top of the sheet. Some cutting and
grinding later I could start over, tacking the edge bar to the
underside instead.
"Shelvse" between the exhaust headers and head light there just
to make it look more tidy at the steering box as the power steering
hoses aren't exactly stylish.
Last Edit: February 21, 2026, 05:43:19 PM by Essex_29
Reply #543 on:
February 21, 2026, 06:03:53 PM »
Totally different work today as I started working on the E-brake.
I got the hand brake from a wrecking yard, cables are standard ones for a Chevy S10.
I cut a hole in the floor and drilled four more for the fasteners.
I got the cables routed pretty nicely, the length of them was pretty much spot on too.
I'm certain that I won't be able to ever destroy the adjuster, it's M12 (just shy of 1/2") thread bar,
The reason for using such over sized materials is I happened to have some M12 round bar
and a corresponding long nut.
It works, even if it's bulky
Reply #544 on:
February 23, 2026, 07:35:51 PM »
Nice fit! Those headers look awesome!
Reply #545 on:
February 26, 2026, 05:01:28 AM »
Thank you
. It feels like having the primaries custom
mandrel bent in stainless was a pretty good decision, they do make
the look I was after.
I took the rear fenders off the car for the Nth time, cleaned the inside
one more time with a wirebrush on the side grinder, then brushed on
rust converter.
I modified a press tool I made a couple years ago and made a shallow
indentation in the right hand side of the dash for the brass Fisher emblem.
Then I dug out all the garnish moldings and sandblasted and ground them
with 320 grit on the D/A.
I made a new todo-list the other day. It?s?. Overwhelming. I will have to
color code the tick boxes to Pre-paint, Driveable and Optional.
Last Edit: February 26, 2026, 05:04:16 AM by Essex_29
Reply #546 on:
February 26, 2026, 05:11:46 AM »
A friend was playing with some ai site online and sent me a pic of my project
he prompted with black paint an flames.
It came out pretty nice. The proportions are slightly off the engine lost a cylinder
Or two and the super charger is mounted? sideways? Fun anyway.
Reply #547 on:
February 27, 2026, 07:55:57 AM »
Essex looking good man. There are so many "unattractive" parts on a car that are just a nessesary evil. But... you keep them neat and in an orderly manner, everbody has to have them😁 And yes like your brake adjuster rod... use what you have works for me👍 Thats why i had such a big hoard of left over and used parts. It cost a lot more to build these things if you were to go out and buy all new stuff.
Anyway... keep up the good work!
Reply #548 on:
February 28, 2026, 08:13:54 PM »
Looks bad ass!
Reply #549 on:
March 03, 2026, 04:00:57 PM »
Thank you
, I do like to make car parts from things that aren't meant
for it. It's good fun, especially when it works and has a different look to it.
You also,
. The AI rendering looks very nice. I did use it to make
a better one in Photoshop, with the right proportions, I'll post that pic from
my phone if I remember to do it. It looks almost the same, you might not see
the difference.
The garnish moldings were primered, ready for a scuff and final paint.
I removed all the removable sheet metal form the car and sanded the parts
with 180 grit.
I covered the body and engine with the same film that I hung up to part off
the painty side of the garage.
After washing everything with wax and silicone remover I sprayed a couple
coats of epoxy on the fenders, aprons, running board moldings and head light buckets.
Today I started block sanding, one of the aprons hardly needs any filler at all.
Sanding is not exactly fun, but it's progress. Tomorrow when the garage should
be suffuciently warm I'll start applying filler.
Last Edit: March 03, 2026, 04:07:46 PM by Essex_29
Reply #550 on:
March 03, 2026, 04:13:28 PM »
Here is the manually adjusted pic.
The wheels are real, as is the engine.
I put the AI pic on top of the real pic and
moved aprons, windows and stuff around to
get the proportions right.
I think it will look mean in black.
Reply #551 on:
March 04, 2026, 09:39:38 AM »
Essex, you've been busy.
Blacks my go to color on most cars, hard to go wrong with that.
Reply #552 on:
March 10, 2026, 02:57:38 PM »
I actually have been pretty busy lately, full steam ahead, spring
is coming fast. I aim to have the Buick driveable May 1st. But it
will be tight.
Since sprayong on the epoxy I?ve been applying filler and sanding
it back off numerous times, feels like more times than ?numerous?.
The fenders are very bad from a ton of welding.
I decided to give up for now, I don?t think I an able to improve
much more on the insides of the front fenders. They?ll be bolted
to the car for easier sanding when I?m done with the insides.
I sprayed on some red primer to get a look at the shapes for as
long as it stayed glossy. A thick coat of epoxy and then fine
sanding will probably have to do. I?ve done my share of filler and
sanding work, even worked at a bodyshop for a year, but this is the
most challenging work I?ve done so far.
Reply #553 on:
March 12, 2026, 06:49:59 AM »
Sounds like you've got a plan. Looking like a good start.
My buddy with my 35 coupe sent me a similar pic of the drivers door with wet black primer on it to show me he was getting it close to start blocking.
Thats my fav part of body work, (i'm weird). Getting the contures/flats smooth and really enjoy the blocking. I could block prime till the cows come home and be a happy camper😁
Reply #554 on:
March 13, 2026, 07:49:25 AM »
Hehe,
I don?t exactly enjoy the work, but it?s very rewarding.
It?s nice when the results are decent, I guess at least I
hate it less than the average guy.
36
37
38
39
42
