Thank you TFoch, for the tip (toe tip) almost made a pun there! I'll try to remember that, but in this case, I'll probably be using a straight piece. We'll see.And yes, sixball, I've benefitted immensely from watching how to videos on youtube, and getting good advice from people on forums. My work would be no where if it weren't for what I've learned from others.More floor work.I welded a 1" sqare tube between the wheel tubs, to weld the floor to,and to give it some structure. I think all this will be plenty strong when it's all welded to a unit.I bent the rounded corners around a pipe. The vertical parts are also slanted, so it made for some interesting pattern making to get right. There's a bead in the center, to make the panels fit flush. Everything will be rosette welded at some point.The upper clamps in the pic is probably right at where the front edge of the rear seat will be.some floor work back there too, to get things all wrapped up. This area is all unplanned still.I did an "oops" on the slanted part of the floor to the right in the pic. I cut too far, and then changed my plans. It bugs me, I might make a new floor part, but it's a fairly big piece of sheet metal, and I'm cheap...
