Author Topic: 11/32 rivets?  (Read 34862 times)
11/32 rivets?
« on: May 01, 2021, 11:26:31 AM »
 I'm working on the '26 roadster frame and I'm ready to put the front crossmember back in. I want to use rivets and measuring the holes it looks like they are 11/32". I have looked on the internet and can not find any. Does any one here if I'm looking for the right size and where I can get them. I could re-drill all the holes and go to 3/8" but I'd rather not do that.  A 11/32" drill goes in the holes but a 23/64" won't.
Re: 11/32 rivets?
« Reply #1 on: May 01, 2021, 04:35:32 PM »
Sixball I did some searching, ran on to "67-72 Chevy truck site. They were discussing 11/32" frame rivets, say rare. A guy popped on and said "rivetsinstock.com" (JC (Jay Cee)) probably had them. I found the site, phone # 248-478-2150. Found under "small solid round head rivets under 7/16".  Might be worth a call or visit site, sure beat drilling all to 3/8" if they have them availible😁
Hope this link works for you,
http://rivetsinstock.com/rivets/solid-rivets/small-solid-rivets/round-head-solid-rivets.html
« Last Edit: May 01, 2021, 04:48:28 PM by sammons »
Re: 11/32 rivets?
« Reply #2 on: May 01, 2021, 07:53:19 PM »
Thanks Sammons, I found the JC site and they do list 11/32 solid steel round heads but when I click to shop on line they are not listed. I'll try calling them Monday. If I could find 9mm it wouldn't be hard at all to drill them. They may be easier to find. (0.34375 to 0.354331) On the crossmember there are 10 holes and I have to drill 8 of them in the frame anyway.
Re: 11/32 rivets?
« Reply #3 on: May 01, 2021, 09:48:11 PM »
Metric rivets on a 26 Chevy  :o
Re: 11/32 rivets?
« Reply #4 on: May 01, 2021, 11:48:34 PM »
Purist, I shouldn't have mentioned it.  ::)  I found this great how to today. I'll probably go 3/8" just a 32nd bigger and plentiful.
http://devestechnet.com/Home/FrameRivets
Re: 11/32 rivets?
« Reply #5 on: May 18, 2021, 08:41:42 PM »
25 3/8" x 1 1/4" rivets arrived today. The forming tool came a few days ago. These will work fine. Some of the old holes accept them. Maybe stretched a bit. I've also noticed some poorly formed heads on several of the originals. If I can I'll fix them. I'll need a smaller tool.
What kind of rust treatment would you suggest between the frame and crossmember? Will it just burn out anyway?
Re: 11/32 rivets?
« Reply #6 on: May 18, 2021, 09:17:08 PM »
Sixball, I use John Deere "Blitz Black" rattle can. I heat up the areas (under both pieces) as hot as i can get it with a propane bottle torch, then spray (quench) it with Blitz. It's there to stay and heat won"t take it off. I'm sure there are plenty of weld thru primers/paints out there, but personally like the Blitz.
Re: 11/32 rivets?
« Reply #7 on: May 19, 2021, 12:48:13 AM »
Thanks, I have some of that. My son's Studebaker wagon is Blitz Black. Been sitting out for years and still cleans up well. I wish I'd used it on my pickup. I have Rust Doctor too and you can weld through it.
« Last Edit: May 19, 2021, 12:49:48 AM by sixball »
Re: 11/32 rivets?
« Reply #8 on: May 22, 2021, 05:22:16 PM »
Maybe I'll send my frame to these guys? Check the guy wearing sandals!
https://www.youtube.com/watch?v=MNSKs0TzlKI
« Last Edit: May 22, 2021, 05:26:18 PM by sixball »
Re: 11/32 rivets?
« Reply #9 on: May 23, 2021, 09:42:08 AM »
OSHA approved!! That guy is a monster with that hammer though.
Re: 11/32 rivets?
« Reply #10 on: May 23, 2021, 10:10:45 AM »
Man my elbows and wrists are screeming just watching that🥴 Must be Pakistan, those guys do some crazy stuff with very little and in risky ways , but seems to work well. You should see them patch/stitch a hole in the sidewall of a big truck tire🤯
Check out youtube  PakistanTruck postings😁
Re: 11/32 rivets?
« Reply #11 on: May 23, 2021, 02:08:28 PM »
They make a great team & their timing is amazing. The hammer guy's swing is fun to watch.
Re: 11/32 rivets?
« Reply #12 on: May 23, 2021, 03:08:44 PM »
Something about molting steel and sandals don't go together
