Author Topic: Milwaukee metal saw  (Read 6441 times)
Milwaukee metal saw
« on: December 09, 2020, 01:31:09 PM »
Needed to cut a 340lb (3/4" thick) piece of steel in half.  Used my Milwaukee metal saw...piece of cake!  Nice clean cut that even a plama cutter couldn't make and a lot faster!
Re: Milwaukee metal saw
« Reply #1 on: December 09, 2020, 02:15:33 PM »
Nice cut.  How much are those blades?
« Reply #2 on: December 09, 2020, 02:46:52 PM »
I always try to find them on sale under $40....I think the saw itself turns at a slower rpm than a regular circular saw.
« Reply #3 on: December 09, 2020, 02:55:13 PM »
That was my next question.  I figured just like metal band saw it would have to be slower.
Saw this Makita Metal Saw for $194 without battery or charger.
« Last Edit: December 09, 2020, 03:04:44 PM by TFoch »
« Reply #4 on: December 09, 2020, 03:54:02 PM »
Used it to cut the 4X8 diamond plate on my car trailer deck...clean and precise cuts.
« Last Edit: December 09, 2020, 06:17:01 PM by EDNY »
« Reply #5 on: December 09, 2020, 04:21:47 PM »
That is quite a cut. I have a metal chop saw from Northern Tool that makes very clean cuts on every thing I've tried except light weight tubing or sheet metal. I didn't trust it on the railroad rail. I finally got that done with a few abrasive blades on 2 Harbor Freight saws. Tool speed is the key. Is that a dedicated metal saw?
« Reply #6 on: December 09, 2020, 06:16:12 PM »
« Reply #7 on: December 09, 2020, 09:36:28 PM »
I have ruined a couple of bottom end table saws by using them to cut tile, concrete blocks and aluminum.
Here is the 18v cordless version. 200 rpm faster, only 2" depth, and no hp rating.
https://www.ebay.com/itm/Milwaukee-2782-20-M18-FUEL-Metal-Cutting-Circular-Saw-Tool-Only/184327956633?epid=24030513777&hash=item2aeacd6899:g:pUwAAOSwYSFePBHb
This one is closer to the corded one.
https://www.ebay.com/itm/Milwaukee-2982-20-M18-FUEL-8-Metal-Cutting-Circular-Saw/184458088253?hash=item2af28f0f3d:g:AxkAAOSwwiVfJkC6
« Last Edit: December 09, 2020, 11:41:37 PM by sixball »
« Reply #8 on: December 10, 2020, 09:46:51 AM »
That's a nice saw and it looks like it did a good job, but Yikes, it's a little pricey. I guess you get what you pay for though. Ed, 3/4" steel? You building a tank?
« Reply #9 on: December 10, 2020, 01:25:06 PM »
Bullet proofing his ride in case he has to venture out to buy more masks or toilet paper. :o
« Reply #10 on: December 10, 2020, 03:30:39 PM »
Actually I'm making a portable target rack and backstop for two targets spaced 3' apart.  I'll post a picture when it's done...it will have provisions for me to move it with the forks on my tractor out back on the handgun range.
« Reply #11 on: December 10, 2020, 06:40:54 PM »
Every gong I have ever set up for 22s and handguns somehow ends up full of rifle holes. :)
