Author Topic: What did you work on today.  (Read 23989 times)
Re: What did you work on today.
« Reply #15 on: April 03, 2013, 09:07:41 PM »
Don, nice looking bracket!  Glad Moose liked it and the pictures.
32chevy vett
  • Retired Die maker
« Reply #16 on: April 03, 2013, 09:26:45 PM »
I don't know how that last photo got on. But it should have been this one. Ghost 28- You can have it for 13.5K . Its all good steel. The only rust is in the rain gutter in the trunk. And on the front fender about 2"in the tire opening. Comes with 2 D.O.H.C. engines. One has a intake with a carburetor and a distributor that runs off the top cam. All new running gear. You will need a truck with an 8' and a trailer. For all the parts that go with it. Mostly new parts.
32chevy vett
  • Retired Die maker
« Reply #17 on: April 12, 2013, 08:41:54 PM »
I work on same thing every day. Monday I primed and painted all the steel. For my winter project. Yes moose I got a photo.
And worked on my bead roller. I have to get a shaft turned down. Then I will paint it and put it together. And take a photo for my buddy. All in fun moose.
« Reply #18 on: April 12, 2013, 09:41:44 PM »
32chevy vett
Looks like you had a busy day. I think you photographic skills have improved to the point to where they almost parallel your mechanical skills. In recognition of this accomplishment and as a reward for your exemplary effort I feel that it's only fitting to give you the following recognition.
« Reply #19 on: April 13, 2013, 10:00:55 PM »
I played around with my new shrinker and stretcher. The inner panel for my rumble seat lid has a little rust so I need to make some pieces to replace the swiss cheese.  I made a cardboard template with the radius of the rear quarter so I could match it.
32chevy vett
  • Retired Die maker
« Reply #20 on: May 26, 2013, 09:51:10 PM »
I finished the roof. And though I may as well build the whole car. So dragged out a frame. And strapped it down for primer.
32chevy vett
  • Retired Die maker
« Reply #21 on: May 26, 2013, 10:00:19 PM »
Here you go moose. The frame I stripped today.
« Reply #22 on: May 26, 2013, 10:01:22 PM »
The roof looks as tight as a drum....Great job!!
« Reply #23 on: May 26, 2013, 10:03:19 PM »
At the speed  you work you must be on flat rate :D
« Reply #24 on: May 27, 2013, 08:10:52 AM »
Just like Ray, busy busy!
32chevy vett
  • Retired Die maker
« Reply #25 on: May 27, 2013, 05:51:38 PM »
Your right Tom that's why I retired. So I could work on my cars. Now I have the time I need the money.
« Reply #26 on: May 28, 2013, 10:12:12 PM »
I worked on my gas tank cover. replacing some rust with new metal.
Does anybody have any experience with the fiberglass covers. If so how did they fit?
« Reply #27 on: May 28, 2013, 10:47:41 PM »
Are we talking about the tail pan panel? If so, the one on my 33 master fit real good...it is a bit "floppy" in the unsupported middle area... plan on gluing a foam brace in the middle on the inside.
« Reply #28 on: May 29, 2013, 07:17:50 PM »
I'm talking about the cover over the gas tank on a 1932 coach. It is attached by 10 bolts including the rear  bumper bracket bolts. Speedway has them listed in their catalog and I was wonder about the quality and fit.
