Author Topic: What Did You do Today - Car Related?  (Read 1048820 times)
« Reply #1005 on: December 14, 2021, 08:26:22 PM »
Yikes, Ed, I never thought it had any real value. Rattiac, come and get it and it's yours!
« Reply #1006 on: December 14, 2021, 08:34:00 PM »
Well, decision pretty much made, going with the 350 trans. here's the engine and trans cleaned and ready for paint, and the engine compartment painted. Good enough for a driver.
« Reply #1007 on: December 22, 2021, 05:26:22 PM »
OK, we got the 350 all painted up and ready to drop it in over the weekend. Not too much trouble, just some elbow grease and masking tape.
« Reply #1008 on: December 22, 2021, 05:36:12 PM »
We dropped the engine in on Monday, went in pretty easy. The little things like motor mounts, trans mount, plugs, wires, etc. start to add up pretty quick, Rock Auto has been my friend on this project. My son decided AFTER we put the engine in that he wants to do away with the A/C. I wish he had told me BEFORE we put the engine in, it would have been much easier to take out the evaporator and stuff on the firewall. A little bit of me wants him to keep it, but I get it, it will be a major undertaking to get it up and running, and no "racecar" has A/C.
« Reply #1009 on: December 22, 2021, 05:41:56 PM »
I did have one minor boo-boo when we put the engine in: it slipped off the leg of the hoist, hit the shifter pawl and snapped off the shifter shaft! Man I was pissed at myself, stupid mistake. I ordered a new one and a shaft seal removal/install tool. From what I read, the shaft can be removed and installed with the trans in the car......I'll let you guys know, I sure would hate to have to pull the trans.
« Reply #1010 on: December 22, 2021, 05:47:07 PM »
Plus you now can change the filter while at it!. Was mentioned before but we have had the best luck with cork gaskets coated with vasoline.  Tightened until the pan and gasket make contact..then 1/4 additional turn.
« Reply #1011 on: December 22, 2021, 07:35:31 PM »
Looks great Chopper!
« Reply #1012 on: December 22, 2021, 08:41:48 PM »
Good job.I'd still be looking at it.  ::)
« Reply #1013 on: December 23, 2021, 07:09:31 AM »
It will be up and gunning in no time
« Reply #1014 on: December 23, 2021, 08:43:30 AM »
Thanks guys! Ed, I just ordered cork valve cover gaskets, I'm gonna give the vasoline a try.
« Reply #1015 on: December 23, 2021, 11:00:30 AM »
Looks good Chopper. Wish you could talk him outta stripping the a/c out. But its his car and it probably don't get as hot up your way as here. I've passed on buying Camaro/Firebirds that kids had pulled a/c out. I didn't care if they didn't work, just as long as it was still there. Hunting up all the brackets/bolts/condenser  etc is a real nightmare.
Those were simple fix's usualy on those, most common was exspansion valve, or leak somewhere.
« Reply #1016 on: December 23, 2021, 07:17:10 PM »
I'm trying Sammons, he already pulled the condenser, most parts are easily available.
« Reply #1017 on: December 23, 2021, 08:03:06 PM »
A/C is a must  just to old to ride around in a hot car
« Reply #1018 on: December 30, 2021, 06:42:02 PM »
Squeezing a little time during the Christmas holiday to do some work on the Camaro. I started installing new tune up parts. I got to the distributor cap and rotor and found the tip of the rotor bent down and plastic ribs in the cap casting broken. I'm sure whoever installed the cap and rotor bent the tip, but why? And, I assume the tip is what broke the casting ribs. Anyone ever see this before?
I attached pictures of the old and new cap and rotor so you can see what I am talking about.
« Reply #1019 on: December 31, 2021, 07:33:36 AM »
I assume that the cap and rotor are used and came with the SBC?  I bet when they pulled the SBC they removed the cap and left the distributor in the block and the rotor snagged something on the way out. Then with engine out the cap was replaced and someone turned the crank by hand causing the cap damage?
