Rear end
8
9
10
11
14
Topic: Rear end (Read 143685 times)
Re: Rear end
Reply #120 on:
March 26, 2020, 08:12:25 PM »
Great start!
Drive it!
Re: Rear end
Reply #121 on:
March 30, 2020, 09:13:07 PM »
Got one of the arm rest framework done. Picture later. Got the carpet, vinyl, cloth, scrim, foam, landau foam and windlace core today. Foams were vacuum packed, had to open and let them relax for a day or so. In the meantime I gutted the interior getting ready for the carpet. Found some surface rust on the floorpan so scraped it and painted with rust converter. Tomorrow I'll paint it with a layer of Rustoleum oil base. The pan had bubble wrap liquid nailed to the floor and a layer of jute over that. Now, my question is: What should I put down on the floor under the carpet? I do have a roll of open cell foam that is aluminum foil on both sides. I've used it on the toeboard and it works real good killing heat. What about the Lowes rubberized flashing, then the foil clad foam and carpet on top of that? Do away with the jute altogether.
Re: Rear end
Reply #122 on:
March 31, 2020, 09:44:25 AM »
I used the rubberized roll of foil flashing from lowes and carpet insulation over that.
Drive it!
Re: Rear end
Reply #123 on:
April 01, 2020, 12:45:03 AM »
Yes, got a roll of it today. Floor is painted and will be ready for sound/heat layer tomorrow.
Next question/poll. What color boarder should I use on the carpet? Here is a picture of a sample with off white and the blue vinyl I will be using on the seats. Keep in mind the car is painted white. Short piece on the end with exposed thread is out.
Re: Rear end
Reply #124 on:
April 01, 2020, 06:42:44 AM »
I'd vote for the white with a blue thread stitching it together.
Re: Rear end
Reply #125 on:
April 01, 2020, 07:00:29 AM »
Just me..but blue on blue?
Re: Rear end
Reply #126 on:
April 01, 2020, 08:40:35 AM »
I like the blue because it matches the seats. (If your seats were white, I would choose white).
Drive it!
Re: Rear end
Reply #127 on:
April 01, 2020, 09:37:31 AM »
Thanks for the inputs, kind of split just like on the home front. Stitching won't show on the carpet BUT will show on the seats and door cards. Torn between using a blue thread or be bold with white. All inputs welcome.
Re: Rear end
Reply #128 on:
April 01, 2020, 07:23:12 PM »
I was going to say something about the stitching...I lean toward blue thread only because if
my stitching got a bit off center
it would be less noticeable?
Drive it!
Re: Rear end
Reply #129 on:
April 03, 2020, 08:42:38 PM »
OK been working on the carpet boarder. Didn't like the puffy look of the vinyl as pictured above. Took a nap and thought about it. Shaved a little off the edge, then sewed the vinyl on. Much flatter and a little more appealing to the eye. Also used blue (teal, because it's what I have) thread. What do ya think?
Re: Rear end
Reply #130 on:
April 03, 2020, 10:40:21 PM »
Looks great......
Re: Rear end
Reply #131 on:
April 03, 2020, 11:09:31 PM »
The TEAL blue/green is a tough color to go right with anything, but as you used it as a high light thread works great.
mike lynch HAIRBALL
Re: Rear end
Reply #132 on:
April 04, 2020, 09:14:54 AM »
Looks like it belongs.
Re: Rear end
Reply #133 on:
April 04, 2020, 09:16:03 AM »
I like it
Re: Rear end
Reply #134 on:
April 04, 2020, 01:55:24 PM »
That looks good.
8
9
10
11
14
Rear end
