Author Topic: 1926 buick roadster  (Read 555237 times)
Re: Build thread 1926 buick roadster
« Reply #60 on: August 25, 2013, 08:58:27 PM »
Wow looks great John!  Nice to see some progress.  It was dusty when I was there in July.
« Reply #61 on: August 25, 2013, 09:02:59 PM »
Oh yeah I had to hit it with the air hose just to find the car. hehe.
« Reply #62 on: August 25, 2013, 09:03:52 PM »
One of the hardest jobs is to get the doors to fit right....Nice work!!
« Reply #63 on: August 25, 2013, 09:07:43 PM »
Thanks. The doors and trunk fit great now, but I am gonna make some adjustable hardware for future adjustment if needed.
« Reply #64 on: January 03, 2014, 01:32:50 PM »
It's been awhile since I did anything on the roadster., but I am gathering parts to further the build. I have all the sheet steel for the flooring, the rear axle, and now I have aquired a front suspension off of craigs list. It came from a 40 ford truck hot rod, but it's actually for a coupe or sedan of the same year because of the drop in the axle. It should work fine under my little hotrod with a few modifications of course.
« Reply #65 on: January 03, 2014, 08:14:42 PM »
The things you can find on Craigslist :)  Nice find!  Glad it's still moving forward.  You are going to change the color right?
« Reply #66 on: February 21, 2014, 07:15:59 PM »
Sometimes I go back and reread my thread to see how far I have come with a project, and to light a fire under my butt, and that is just what I did. I forgot what the car looked like when I got it and where it is now. THIS HELPED. I have started on the front crossmember for mounting the 40 ford spring. I cut some steel with my plasma three pieces and then welded them together. they are ground down and the crossmember is tacked in place to hold the wheel base I want.  Maybe this weekend I can get the boxing plates cut and installed on the front of the frame. This will secure the crossmember in place and also make the front frame section a little more rigid. Then the bones will have to be split and bent so I can use them for adjustment of the axle front to back on each side.  A little progress is at least something....John
« Reply #67 on: February 21, 2014, 10:14:04 PM »
John,
Glad to see some progress.  It's going to be a cool ride.
« Reply #68 on: February 23, 2014, 07:45:23 PM »
John,
Thanks Tom it's starting to be fun again. I got the boxing plates cut for most of the front frame, I don't believe I need to box the whole frame because this frame is thick and heavy unlike the chevies or fords of the same year. I did get them installed and cleaned up for the most part it looks a lot better at the front with the new crossmember. Have a look.
« Last Edit: March 04, 2014, 09:26:54 PM by ghost28 »
« Reply #69 on: March 02, 2014, 06:56:30 PM »
Well I split the bones and cut them so I could tweak them further out and under the frame. Some guys don't like doing it this way but I have never had a problem doing it. What I dont like is heating the spring perch area and bending it as much as I would of had to to achieve where I wanted the bones to end up.
« Last Edit: March 04, 2014, 09:29:57 PM by ghost28 »
« Reply #70 on: March 04, 2014, 09:52:51 PM »
Thanks Ed. I went and shrunk all my pictures of the buick. They look a lot better when you don't have to scroll them side to side.
« Reply #71 on: March 04, 2014, 10:26:26 PM »
Thank you for doing that ghost...I set mine at 900 which still fits nicely on the page.
« Reply #72 on: March 23, 2014, 02:01:39 PM »
I am getting a little work done on the flooring for the roadster. I cut all the sheet steel and burned some holes in it to puddle weld it to the lower floor structure, the hardest piece was the curved one in the trunk area since I dont have a brake, but it's done and tacked in place with all the rest. Once this is finished, I am gonna start on the rear fenders mounting them so I can see where I want to bob the rear of them. Have a look.
Re: 1926 buick roadster
« Reply #73 on: March 23, 2014, 07:12:56 PM »
Nice work John!  Floor looks great!
« Reply #74 on: March 23, 2014, 07:48:57 PM »
Great looking project! That is a lot of work!
