Author Topic: Front turn signal ideas  (Read 29367 times)
Re: Front turn signal ideas
« Reply #15 on: December 18, 2016, 01:18:49 PM »
You can always mount them on your cowl ( i.e. 32) and make them a dual purpose light driving/parking and turn signal and you can do it with a single element bulb. Somebody posted that circuit on here a few months back.
« Reply #16 on: December 18, 2016, 03:36:51 PM »
Tom, can you see your turn signals when your headlamps are on? The reason I am asking is I bought that style lamp for my buddy Lonnies '32 Ford p.u. from Speedway I think. If the headlamps were not on you could see them flash, but with the headlamps on from across the street(day or night) you couldn't see the amber(LED) flashing. Just curious what brand you used.
« Reply #17 on: December 18, 2016, 05:25:32 PM »
Mike...is the top lites, Amber ones  from a Harley??
I TYPED IN HARLEY LIGHTS OR LITES INTO EBAY SEARCH AND WAS ONE OF MANY TYPES THAT TURNED UP .  THOUGHT THEY ARE PRETTY SLICK AND EASILY MOUNTED SOMEWHERE ON FRONT OF A CAR.   SEE IF I CAN FIND THEM AGAIN AND POST LINK TO THE ITEM
MIKE
FOUND THEM...........
http://r.ebay.com/d6laBM
« Last Edit: December 18, 2016, 05:32:05 PM by madmike3435 »
« Reply #18 on: December 18, 2016, 06:39:25 PM »
Got it ...Thanks Mike
« Reply #19 on: December 18, 2016, 08:35:40 PM »
Sammons,
I got mine from American Antique Auto Parts http://www.aaaparts.cwmax.com/chevyhl.htm
Great question about if you can see them with the headlights on.  Didn't know the answer so I went out to the garage and checked it out in the dark.  I do have halogen bulbs and I can see the turn signals flashing with the headlights on.  Tried to take a picture but didn't come out.
« Reply #20 on: December 19, 2016, 05:30:05 PM »
I'm using the headlamps with small LED bulbs that plug in the back of the lamp. The LEDs are single element so you need to run a splitter with resister/diode to have both running and directional lights. I can set you up with resistor/diodes at no cost..have a ton of them.
« Reply #21 on: December 19, 2016, 05:38:40 PM »
My son has a set similar to these on his 37 Chevy and you can see them no problem day or night and they have parking and turn signal capabilities. Really light up great.
« Reply #22 on: December 20, 2016, 05:24:25 PM »
I use the same as TFoch......I have no front fenders  :)
« Reply #23 on: December 29, 2016, 08:30:35 AM »
I have done something similar to this but with 3 shorter slots
DLRIDES
« Reply #24 on: January 24, 2017, 01:21:21 PM »
Use some original cowl lights (easy to find), convert the socket to a dual filament or led panel. The look will blend with the car.
"Billet and chrome is for those who can't build their own."
