Author Topic: Trunk prop rod???????  (Read 15643 times)
« on: July 25, 2015, 09:10:57 PM »
Small dilemma............... after building this car and then in my haste to paint it, I forgot one important thing. A trunk prop rod. I don't have the original. Anybody out there have one? How about some ideas on what you guys are using? Thanks in advance.
Re: Trunk prop rod???????
« Reply #1 on: July 25, 2015, 09:51:57 PM »
I did the same thing. No prop rod in place, I'll  figure it out hopefully or I will steel your idea.  ;D
« Reply #2 on: July 25, 2015, 10:27:24 PM »
OK Ghost, whoever comes up with an idea first! :)
« Reply #3 on: July 25, 2015, 10:53:27 PM »
« Reply #4 on: July 25, 2015, 11:34:58 PM »
i forgot about that Ed. on my way to my shop to look for the pair I took a chevy blazer about the same year.  Thanks
« Reply #5 on: July 27, 2015, 09:35:53 AM »
Thanks, Ed!!
« Reply #6 on: July 27, 2015, 10:23:57 PM »
This is for a hood but I think it could be made to work. ::)
« Reply #7 on: July 28, 2015, 08:39:37 AM »
  I'll bet I could make that work for my trunk.  funny ;D
Wally
« Reply #8 on: August 19, 2015, 10:06:25 PM »
Anyone ever try these? I have seen these used and they function great for deck lids.
Most deck lids are light enough that you only need one hinge. They sell in pairs so you'll have a extra
for your next build or you could just sell it to a friend who needs one.
http://www.ebay.com/itm/ALUMINUM-HOOD-HINGES-D393826-19-1-2-/262004378726?hash=item3d00ad8c66
I can send someone a picture if they want to post it on here so they can see what they look like installed.
I posted the eBay link just as a example of what these hinges look like. I've seen other styles like round holes drilled in them instead of oval holes. When you want the deck lid to stay up you just pull the hinge toward you a little bit. The hinge will kind of lock in place.
When you want to close it all you do is push the hinge away from you and then you can close your deck lid. One word of caution.... Because the hinge has a scissor motion you can pinch your fingers if your not careful.
« Reply #9 on: August 19, 2015, 10:58:04 PM »
Mechanically they look to work like a stock hinge..they just look better. If you want them...don't think too long..they are Buy It Now.
« Reply #10 on: August 20, 2015, 06:09:07 PM »
Thanks, Wally. I like those, but then it's a matter of mounting, and clearance issues when it is folded closed. I am thinking a little more low-tech, simple and cheap. This is what they used on Furds:
 http://www.ebay.com/itm/371281547604?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_22wt_867
What did they use on the old Chevy's? I can't find anything, not even a picture.
I REALLY should have addressed this BEFORE I painted the car!
Wally
« Reply #11 on: August 20, 2015, 08:42:15 PM »
I have a friend who has a 1927 model T coupe with the gas tank in the trunk. There is no room in the trunk but he has the hinge that I showed you on eBay holding up his deck lid. ( I keep saying hinge but it's more of a prop rod and not used as a hinge )
« Reply #12 on: August 20, 2015, 08:58:54 PM »
Wally, if you have a picture of it installed I wouldn't mind taking a peek.   Jim
36 burban
« Reply #13 on: August 21, 2015, 09:37:40 AM »
look at a 65 corvair  . the one in the engine compartment. it worked on my 31 and bolts in with 4 screws or bolts
