Author Topic: Cowl I.D. help needed  (Read 7163 times)
« on: June 08, 2015, 09:11:06 AM »
I picked up this cowl to cut out some patch panels I need to my firewall.  First off if any body needs any parts off of this let me know.  Secondly, I need to I.D. the cowl to post some adds on Craigslist and such.  I think it is for a truck....maybe '37-'38....just a guess on my part
Chuck
Re: Cowl I.D. help needed
« Reply #1 on: June 08, 2015, 09:35:12 AM »
Comparing those pictures..it looks "identical" to my son's 37 Chevy Master 4 dr sedan.
« Reply #2 on: June 08, 2015, 05:47:15 PM »
It could also be a 1938
« Reply #3 on: June 08, 2015, 05:53:29 PM »
You are probably correct, but it is exactly identical to the 37 sedan I'm working on..including the dash layout. Most of the parts listed for these cars cover the 37-39 range.
« Reply #4 on: June 08, 2015, 06:02:59 PM »
To bad the body tags are missing that would answer the question.
« Reply #5 on: June 08, 2015, 07:21:44 PM »
Here's a shot of the 37 inside
« Reply #6 on: June 08, 2015, 07:23:47 PM »
ED what is the piece on the garnish molding above the steering wheel?
« Reply #7 on: June 08, 2015, 07:24:52 PM »
adjustable window defrost vent
« Reply #8 on: June 08, 2015, 07:29:12 PM »
I went back and looked at the picture closer and see that the front window garnish molding is different between the  37 and 38,  The 38 has the defrost vent openings made into the garnish molding.
« Reply #9 on: June 08, 2015, 07:32:56 PM »
Here's a close shot...the 2nd pictures is the id plate area..the fender was molded in.  I moved the master cylinder mounting holes.
« Reply #10 on: June 08, 2015, 07:40:30 PM »
What I've been told is the hood, grille, radiator shell are the big differences between the two years, also I was told that there is a 1 inch difference in the width of the rear fenders the 37 being the smaller ones.
