Author Topic: Need headlight buckets for 37 Chevy  (Read 17161 times)
« on: May 19, 2015, 10:54:57 PM »
Need a set of the buckets that secure the headlight bulbs inside the headlight bodies for my son's 37 Chevy.
Sample picture attached.
« Last Edit: May 20, 2015, 07:24:55 AM by EDNY »
Re: Need headlight buckets for 37 Chevy
« Reply #1 on: May 20, 2015, 06:24:49 PM »
Just curious Ed. What headlights are you running that you would need those backings, and does the stock 37 buckets need those in them? They must be a larger around than I remember.
« Last Edit: May 20, 2015, 06:32:22 PM by ghost28 »
« Reply #2 on: May 20, 2015, 06:30:04 PM »
Ed  I might have set out of my 38. I'll check when I go back to the garage tonight and let you know.
« Reply #3 on: May 20, 2015, 08:11:02 PM »
Now that you ask..I'm not sure what I need...here is a picture of what I have, neither one has a head lamp or trim ring.
(Approx 6-1/2" to 7" across).
« Last Edit: May 20, 2015, 08:15:37 PM by EDNY »
« Reply #4 on: May 20, 2015, 09:12:21 PM »
Ed I do not have the adjuster which is needed. I have a set of trim rings. Also have a used  French  kit if I can find it. There yours if you can use them.
« Reply #5 on: May 20, 2015, 09:42:01 PM »
Sending a PM
« Reply #6 on: May 21, 2015, 05:45:07 PM »
Ed  shipped the package today you should see it the first of the week. I also found the French kit.
« Reply #7 on: May 22, 2015, 07:21:06 AM »
Thanks..I'll be sure to at least pay the postage.
