Author Topic: Dodge springs in the 37 Chevy sedan  (Read 10822 times)
« on: May 10, 2015, 11:31:11 AM »
1 of 3
At the suggestion of using Dodge springs by vette59jdwl I bought a new set of 48" Dodge springs from SD Truck Springs for about $130 delivered for two.
I only used the main spring and installed the Blazer middle and bottom spring so they wouldn't be too stiff.  Drilled out the Blazer springs so I could install nylon sliders on each end.  The Dodge springs are 2.5" wide so I removed the front springs perches from the 37 and relocated the inner bolt tab.
« Last Edit: May 10, 2015, 11:41:20 AM by EDNY »
Re: Dodge springs in the 37 Chevy sedan
« Reply #1 on: May 10, 2015, 11:36:13 AM »
2 of 3
Next I widened the stock rear shackles by welding a piece of a 39 Chevy shackle I had (note holes are tapered). The setup let's me use the oem top swivel and offsets from the stock 1.75 spring to the new 2.5 spring.
Need to finish up with upper grease fitting and wider lower bolt.
« Reply #2 on: May 10, 2015, 11:40:22 AM »
3 of 3
Picture of the springs mounted....still need to install lowering blocks. Nice spring action and cost about $150 to complete the entire spring swap.  Won't need to worry about sagging springs.
P.S
Wayne Thanks for the Dodge spring tip.
« Last Edit: May 10, 2015, 11:42:59 AM by EDNY »
« Reply #3 on: May 10, 2015, 12:07:23 PM »
That worked out real nice Ed. Kudos to Vette59.
« Reply #4 on: May 10, 2015, 12:24:16 PM »
Looking good Ed  vette59jdwl
« Reply #5 on: May 10, 2015, 12:33:50 PM »
Will look better once it's all painted. Used the shock plates and U-bolts from the Blazer. Already made a set of 2" lowering blocks with rear axle offset and larger hole for the Dodge spring clamping bolt...and have a set of longer U-bolts hanging on the wall.
« Last Edit: May 10, 2015, 12:35:38 PM by EDNY »
« Reply #6 on: May 12, 2015, 02:54:32 AM »
Clever, Ed. I like the widened shackle.
« Reply #7 on: May 12, 2015, 07:06:02 AM »
Great job for not a lot of $$.  I'm sure your son appreciates it.
logride
« Reply #8 on: May 12, 2015, 07:51:46 AM »
Lots of good ideas Ed!
« Reply #9 on: May 12, 2015, 08:45:53 AM »
Very nice Ed!
« Reply #10 on: May 12, 2015, 08:54:33 AM »
That is some really nice detail and thought on the mounting of the springs.
« Reply #11 on: May 12, 2015, 05:45:30 PM »
Ed you sure had a great ideal there thanks for sharing with us.
