Author Topic: 65 GTO Convertable  (Read 9165 times)
65 GTO Convertable
« on: April 20, 2015, 11:03:48 AM »
 Guy's  I wish to know if the 1965 Pontiac GTO is a speciall frame or if it is on a stock or modifies Chevelle / Beaumont frame and what fits what thanks vette 59 jdwl
« Last Edit: April 20, 2015, 03:07:31 PM by vette59jdwl »
Re: 65 GTO Convertable
« Reply #1 on: April 20, 2015, 01:43:05 PM »
you need to know what PLATFORM they built the Pontiac gto and the chevelle on, that will answer your question , because unfortunately I do not know.
But I telephoned my friend at GM Oshawa and he said the gto 64-65 is built on the tempest platform. Common to Pontiac only.
 Starting in 1967 the gto-- chevelle ---buick skylark--olds cutlass were built on the same platform as are other models built on specific platforms
mike                8)
« Reply #2 on: April 20, 2015, 03:06:07 PM »
Thanks MadMike I also found out same as Skylark 64 to 67 the Hard-top frame is not boxed like the convertible frame is El camino also the same but a little longer behind the rear wheels A body frames changed in 67.Thanks again  vette59jdwl
« Last Edit: April 20, 2015, 04:37:56 PM by vette59jdwl »
