Author Topic: 31/32 chevy coupe or roadster  (Read 13174 times)
« on: February 06, 2015, 09:29:31 PM »
  I know this has been asked before. Does anyone have measurments or a schematic of any of the wooden parts for either a 31/32 chevy coupe or a 31/32 chevy roadster. If anyone needs the measurments or parts for the doors I have them ,.If anyone need the frame rails for either I have them. vette59jdwl.  Looking for measurements on cross members and or any uprights along with the measurements for the boot. Convertible top  thanks
Re: 31/32 chevy coupe or roadster
« Reply #1 on: February 06, 2015, 09:39:30 PM »
What parts for the doors do you have ? I'm looking for a set of  lower hinges.
« Reply #2 on: February 07, 2015, 12:07:02 AM »
  I built me one of those copier duplicators and i am making copies of all the wood. I got my drivers door for the roadster from Don Beals and am happy as hell with what i got. I have made three complete so far for the roadster 32 and am working on the passengers side door as we speak. I have no idea where you would get the metal parts for the doors. I have what came with my car and will be using all the original equipment I am using a 250 with a 57 truck bellhousing an 11 inch flywheel and a 5 speed stick with a 1989 Dodge D-50 rear end  wanted juice brakes and everything else to make it look almost original sort of a restomodI will talk with Glen Rarick tomorrow evening and ill ask him he might know. vette59jdwl
« Reply #3 on: February 07, 2015, 12:21:14 AM »
I am also looking for patterns or pieces any parts or pieces for 32 coupe or roadster. I have the main frame rails all 5 cross members and the doors for the roadster so far. I was going to take the cowl off this weekend but mother nature dropped another 6 inches on my portable garage and pooof  down she came I will not be able to evaluate the damage till spring. and now tonight dang weather man says another 20 centimeters. OK enough winter can go south  vette59jdwl
« Reply #4 on: February 07, 2015, 08:22:48 PM »
62131  I called glen and he was out plowing. He called me a few minutes ago with a message  were you looking for lower hinges for a coupe or a roadster he left me a message saying he had both. give Glenn a call  up state New York 1 315 658 2661  he is in now  vette59jdwl
« Reply #5 on: February 08, 2015, 10:08:48 AM »
I'm actually looking for a set of lower hinges for a 2dr sedan, I will give him a call.
Thanks for the lead.
« Reply #6 on: February 08, 2015, 10:19:00 AM »
Just a reminder...the contact info for Glen Rarick is listed below...I just made a copy of his business card.
redsshed77
« Reply #7 on: February 12, 2015, 01:59:40 PM »
are you making the wood main rails or just the measurements.looking to replace a few pieces of my wood.
« Reply #8 on: February 13, 2015, 01:13:31 AM »
  Redsshed77   I am making the main rails for either a 31 coupe or roadster or a 32 coup or roadster I am making them out of Two sheets 3/4 inch plywood with 1/8 inch glued and screwed in between for a total thickness of 1-5/8 inches. I am also duplicating the wood for the 1932 chevrolet roadster not sure if 31 is the same or not.
  What i wish to do is to make patterns or copy any particular piece and then make copies. I have read to many times of people just destroying the wood out of their cars and then tomorrow someone is looking for information and measurments say for a door block to hold a door lock mechanizm ??????what did you have in mind   vette59jdwl
