Wood & Framing Section
Interior framing progress
3
Topic: Interior framing progress (Read 25322 times)
January 16, 2013, 12:19:55 PM »
Removed a bunch of cow stanchions from my barn and been using them to frame up my 33. They are about 1/8" thick and wrap nicely around the interior body. Have plenty if anyone needs some.
That's 1/8" steel running the length of the B pillar -roof to floor-and welded to the stanchions.
Re: Interior framing progress
January 16, 2013, 12:32:29 PM »
Ed,
Excellent reuse of material! Looks good. I'm all set on mine though but could have used it a while ago.
tom
January 16, 2013, 12:51:20 PM »
Now that's pretty crafty! Look like they were made for the job....but now what you gonna do with the cows?
January 16, 2013, 05:34:22 PM »
Dnag. You are a pretty fart smeller I- I- MEAN SMART FELLER. It reminds me of a time I used a bar stool hoop for a steering wheel on my 28 chevy.
January 16, 2013, 06:27:08 PM »
The manure is pretty old - while welding it kinda smells like roses
Those stanchions really are stout...& like I said...have plenty if anyone needs them.
32chevy vett
Stovebolt
Retired Die maker
January 16, 2013, 09:17:50 PM »
That sounds like some thing I would do! Great idea.
January 21, 2013, 10:18:38 AM »
Progress shots, have the coupe all boxed in with 1" round .095 tubing....including the wrap around the rear window, A pillars connected at top, behind dash and floor. It's really sturdy and before I put the interior up, I'll use small amounts of automotive spray foam between the body and round tubing. Most of the new car pillar are filled with the stuff now.
The tubing actually uses less space than the OEM wood and gives me a base to attach the garnish molding tabs.
Will most likely use some round stock framing the inside of the doors. The guy I bought the body from tried to make his own wood framing...I say "tried" plus he used softwood.
Last Edit: January 21, 2013, 10:27:44 AM by EDNY
Reply #7 on:
January 21, 2013, 02:19:31 PM »
It looks like it's coming along really well. That's a good idea using the spray foam...That should really keep the vibration and noise levels down.
Reply #8 on:
January 21, 2013, 02:46:43 PM »
I know there was a debate (HAMB) about using foam in a streetrod but just about every new car has it. It is a special closed molecule foam that won't absorb water or moisture and really strengthens a body and it weighs nothing. I'll run pex tubing through the A pillars then foam up the pillars. That way the round .095 tubing which is already welded to the body inside the pillars will be even more rigid... the pex will be there to run wires through.
The pictures look a little rough, the guy before me sprayed the inside of the car with all kinds of paint but I'm satisfied with the framing inside the car.....still need a few small supports and gussets...but the doors are next.
Reply #9 on:
January 21, 2013, 05:52:23 PM »
Looks good, Ed. I like the foam idea, too. I think I will give it a shot.
Reply #10 on:
January 21, 2013, 07:15:32 PM »
Ed,
It's looking good and should be real solid. The foam idea is a good one. I'll have to think about that. Great job!
Reply #11 on:
April 20, 2013, 09:38:56 PM »
Any updates on you coupe?
Reply #12 on:
April 21, 2013, 07:03:30 AM »
Quote from: ghost28 on April 20, 2013, 09:38:56 PM
Have the door chop sections tac'd together, doors framed, TPI engine running, exhaust done. When (if) the sun comes out for good I'll start working on the external body including rounding the bottom of the rear fenders, roof panel welding. Welded in a front bumper wedge style. Waiting for a couple of guys to help me tac the roof panel in.
The best part is that it's running, charging and moving!
Reply #13 on:
April 21, 2013, 08:24:45 AM »
Ed,
I see you provided pictures of proof for Moose!
Reply #14 on:
April 21, 2013, 08:49:36 AM »
Ahh come on Tom...You know you like looking at all those great pictures too!!!
Quote from: TFoch on April 21, 2013, 08:24:45 AM
Ed,
3
