Author Topic: Polishing.  (Read 9389 times)
Kiwijeff
Polishing.
« on: December 18, 2014, 04:07:49 PM »
The guys at the local wreaking yard get me to do all their polishing as well as their painting.
Here's what I did for them recently.
Re: Polishing.
« Reply #1 on: December 18, 2014, 04:16:51 PM »
You need to tell us more...ie wheels...polishing compound grit etc.. :P :P :P
Re: Polishing.
« Reply #2 on: December 18, 2014, 05:01:23 PM »
Are those old fire extinguishers Kiwijeff ?
Kiwijeff
Re: Polishing.
« Reply #3 on: December 19, 2014, 06:37:06 AM »
Nothing to flash for me, I'm cheap.  ;)
I start with 320 wet n dry sandpaper on the real dirty stuff.
Then move to 600, and maybe 800, before finishing with 1200 wet n dry.
Once that's done, (depends on arm strength) I do the final polish with Auto sole, but prefer Mothers metal polish.
After that, to keep it from dulling off sooner than later, I use car wax.
Polishing sucks, but I like the results.
Re: Polishing.
« Reply #4 on: December 19, 2014, 08:47:02 AM »
Are you using wheels or doing this by HAND?? I did the valve covers and scoop for my car, but even with those after sanding I used a small wheel on the drill. I think it would have taken forever if I did it by hand.
Kiwijeff
Re: Polishing.
« Reply #5 on: December 19, 2014, 05:41:18 PM »
All done by hand Chopper. :)
Re: Polishing.
« Reply #6 on: December 19, 2014, 06:45:32 PM »
I polished an aluminum wheel by hand following the same procedure Kiwijeff used and it takes very little machine polishing after that to bring out the luster.
