Author Topic: Hinge mirrors  (Read 6233 times)
Hinge mirrors
« on: July 07, 2014, 09:33:21 PM »
Im trying to make me some Hinge style mirror mounts. The flat-steel is bent and ready to drill but...
I cant get the hinge- pin out  . Any recommendations ?
Re: Hinge mirrors
« Reply #1 on: July 07, 2014, 11:40:16 PM »
Them can be tough. If heat (torch) is an option,  open the door and heat the cowl side (upper/lower) ends of the hinge and tap up. I borrowed a clamp style press from a friend and broke it, ordered 2 more, give my buddy one for the one I broke. I resoaked in PB blaster for a few more days, then broke my new press also. I didn't have a oxy/set torch to heat with. I ended up drilling out the bolts and took hinge off. Once off I could get a good backer (vise) ground down an air chisel to size and it drove right out. Problem with trying that on the upper hinge is you can't get a straight shot on the pin due to the curve of the body.
Good luck, maybe one of the above will help.
Re: Hinge mirrors
« Reply #2 on: July 07, 2014, 11:45:35 PM »
The best STUFF i have used  one half transmission fluid  the other half Nail Polish Remover. ACETONE  Put in a spray bottle be careful not to get it on any paint and do not sniff the fumes.This STUFF really works  mooseman
Re: Hinge mirrors
« Reply #3 on: July 07, 2014, 11:55:09 PM »
59, i'm gonna have to try that mix sometime. I think i've heard of that before, only I may sniff a little.lol
Re: Hinge mirrors
« Reply #4 on: July 11, 2014, 07:56:06 PM »
I found a way of getting around this pin dilema . Make em' clamp on . drilled out so that the top/bottom of the pin hold it tight and using a small bolt (or 2) to clamp it down . Ive already made my first set but I dont like em" and starting on a (much improved) second set .
Re: Hinge mirrors
« Reply #5 on: July 11, 2014, 08:01:04 PM »
Trial and error, man we go through a lot of that with this hobby.  Every protptype gets better and better! Sounds like you got'er going on.
Re: Hinge mirrors
« Reply #6 on: July 11, 2014, 09:35:24 PM »
Here's an old post...my buddy made some brackets that bolted to the hinge...then he used a set of Harley mirrors I gave him, pictures are posted.
Link:
http://rustybowtie.com/index.php?topic=892.msg6624#msg6624
