Author Topic: A/C help  (Read 6495 times)
A/C help
« on: August 19, 2023, 11:00:16 AM »
I have never done any a/c work and just installed vintage air in my 1953 3100. All seems to have went well with evacuating the system holding -29 psi overnight. When charging I admittedly got confused and I'm sure I did something wrong. Vintage Air says acceptable operating pressure ranges should be 160 to 270 psi on high side and 10 to 20 on low side. This is what I ended up with.
Looks like I am low on the high side and extremely high on the low side. Any advice is greatly appreciated. Thanks
Re: A/C help
« Reply #1 on: August 19, 2023, 11:42:26 PM »
Is some hose hooked up backwards  ?
Re: A/C help
« Reply #2 on: August 20, 2023, 11:24:29 AM »
no, the fittings are different sizes and will only hook up one way.
Re: A/C help
« Reply #3 on: August 21, 2023, 03:56:38 PM »
make sure the orifice tube is not damaged and that the O rings are in place.
