Author Topic: 1930 Chevy Coack luggage rack.  (Read 18258 times)
« on: July 06, 2023, 12:26:45 PM »
I want to put a luggage rack on my 1930 and am  having a hard time finding one. I did  find one rack on ebay but no hinges. I don' really know how they mount either. Can someone help?
Re: 1930 Chevy Coack luggage rack.
« Reply #1 on: July 07, 2023, 09:53:48 PM »
Speedway sells one and it folds up. Looks like it mounted through the bumper brackets.  It's for a Ford....but really,  who's gonna know.
« Reply #2 on: July 07, 2023, 11:09:24 PM »
Oh, The Ford guys will know.  ;D  The question is who cares? If it works for you go for it. A lot of that stuff was after market or at least came from outside suppliers.
« Reply #3 on: July 10, 2023, 06:51:07 AM »
I have an original one. Found it buried under the junk that was in my 32 when I bought it. I I remember correctly it mounts to the rear apron bolts. I can dig it out and confirm that If you would like. I found a trunk to go along with it. just never got around to putting on my car.
« Reply #4 on: July 10, 2023, 02:41:01 PM »
If it is not  to much of an inconvienance, could you send pics.
« Reply #5 on: July 10, 2023, 09:54:22 PM »
Sure will. give me a day or two
« Reply #6 on: July 11, 2023, 11:26:03 AM »
Sure, thanks...
« Reply #7 on: July 11, 2023, 01:46:20 PM »
Here is a few pictures if you want some more just let me know. It's missing a support arm on what would be the right side when mounted,
« Last Edit: July 11, 2023, 01:50:50 PM by 62131 »
« Reply #8 on: July 12, 2023, 11:33:26 AM »
Thank you sir, it looks just like what I found. I also found the brackets at I&I Reproductions. When I get everything I'll try to figure out just how it fits. The brackets that are wielded on must go through te tank cover. Do you think that is right?
« Reply #9 on: July 12, 2023, 09:25:59 PM »
I haven't looked at it that close, I think that's right, the two little brackets are mounted with the rear apron cover bolts. When its opened the two longer arms come down and rest against the rear bumper brackets.  I'll look at it closer and let you know.
« Reply #10 on: July 14, 2023, 10:13:16 AM »
Thanks for the help, I should get thr rack on Monday. It is hard to tell, but those brackets might be missing. I hope not...
« Reply #11 on: July 18, 2023, 05:58:03 PM »
This is what I got today. Does it match yours? Mine needs to fit a 1930. I have no idea how this mounts.
Ideas?
« Last Edit: July 18, 2023, 06:04:28 PM by munch »
« Reply #12 on: July 19, 2023, 07:41:07 AM »
I'll look at mine closer this afternoon I'll be in the garage putting new tires on my mower. Bought a new set of tires for a mower is like buying a set of tires for a automobile. :(
« Reply #13 on: July 19, 2023, 10:31:49 AM »
Must be a big mower...
« Reply #14 on: July 20, 2023, 04:44:29 PM »
Took some measurement s, it mounts on the upper rear apron cover bolts. When unfolded there's two arms or supports that rest against the rear of the apron or bumper spring to support it, there's rubber bumpers on the arms to protect the paint, I think you can only use the rack if you have a split bumper, not sure about that, here's a couple more pictures,
« Last Edit: July 20, 2023, 04:53:28 PM by 62131 »
