Author Topic: Rear axle identification  (Read 8973 times)
« on: December 10, 2022, 03:54:32 PM »
I have a GM rear end 3894859 that has 28 spline axles and the length is 28 1/2 inch from outside flange to end of axle. Thought the rear end was out of a 70s Camero, but I cannot find that length anywhere. It appears to be a 8.2 by the rear cover design and has the c-style clips to hold the axle in.
Does anyone have any ideas. As always, thanks.
Re: Rear axle identification
« Reply #1 on: December 10, 2022, 05:52:23 PM »
« Reply #2 on: December 10, 2022, 06:37:59 PM »
« Reply #3 on: December 11, 2022, 10:46:36 AM »
This might help:
https://store.tracyvette.com/item/1716/
Thanks Ed, but I don't see the axle length.
Sorry..guess I don't fully understand the question.  Have a pile of GM rear ends in my barn.
« Reply #4 on: December 11, 2022, 11:49:45 AM »
This might help:
The axles I pulledd out of this rear end need replacing. All I know is the code on the rear end is 3894859 N and it is an 8.2 supposably from a 69 or 70s era Camero. The axles are 28 spline and are 28 1/2 from back  of flange to end of axle. I cannot find any that length. Thank  Ed
« Reply #5 on: December 11, 2022, 12:27:02 PM »
Found this set off to the side..28 spline, 4-3/4" bolt pattern?
« Reply #6 on: December 11, 2022, 04:36:00 PM »
Do they measurer 28 1/2 from back of spline to the end? Thanks for looking...
« Reply #7 on: December 11, 2022, 06:10:28 PM »
Sure looks like it..if you can use them they are yours...just getting in the way anyway.
« Last Edit: December 11, 2022, 07:33:53 PM by EDNY »
« Reply #8 on: December 11, 2022, 08:39:05 PM »
Great part about this hobby is we're all trying to help each other out!
« Reply #9 on: December 12, 2022, 07:05:57 PM »
This little group is amazing. There is more help and support here than there are people.  :o :)
« Reply #10 on: December 23, 2022, 10:58:20 AM »
Thanks Ed, soeey it took me so long to get back. I tend to get side tracked a lot lately. Right after I responded to you I located the axles. Thanks for the offer, all you guys are great...
« Reply #11 on: December 23, 2022, 06:01:53 PM »
No problem...looks like I found another set!
